I had to get a 53.5 inch Crank/water pump/alternator V-belt today and it was almost discouraging with the lack of parts for our old vettes at chain parts stores. I finally found a high performance correct V width & angle online through NAPA. the belt is designed to get tighter as it heats up.
I caused the problem. Old belt and the first sunny 70ish degree days. Vette has been down for the winter. So I took it off the stands and drove over and filled it with Super Unleaded and took and afternoon test drive on the lonely highways here in Nevada. I ran it up to the rev limiter through the first 4 gears quite a few times and cruised at high speed in OD with my 4.11 rear. It just purred along. I got home and looking under the hood and what ever reason the belt I had didn't spit off, it was flipped and riding around on the thick side. I have deep grove March aluminum smaller diameter crank pulley. kinda stock water pump diameter and larger alternator.
Real farm implement dealers (e.g. AGCO, M-F, New Holland, Deere, Case etc) typically have a broad selection of V belts (bearings as well). AG equipment typically has much longer service life than passenger cars.
Serpentine supplanted cars' V belts Looong ago. Parts houses' computers KNOW which parts are popular & relevant; ranks them and reorders accordingly. SOP for years.
Not sure what engine you're dealing with, year, etc. In my case, an '80 L82 there was all kinds of conflicting information for what were the correct belt sizes.Part of the issue was that even though all three engine options that year use the same block, the belts for the accessories for some reason are different. Often the differences were 1/2 inch length. I went onto Rock Auto and found they had several by decent makers which differed maybe 1 inch in length. Many were on clearance and selling for $2 or $3. So, I just bought an assortment of them for three belts I needed and found the ones that fit the best.
I did have a memory refresher on what the numbers mean. Example for a 79 L-82 corvette from Napa:
The last three digits of the 257530 Stands for 53.0 inches Because of my altered pulleys I bought three sizes in one trip the 53 inch and couldn't even get the belt on with my bigger alternator against my taller valve covers. The 257540 being 54 inches would work if you wanted the alternator out at the end of the upper arced tension bracket. The 257535 fit perfect at 53.5 inches and I just return the other two
I was wrong on the numbers corresponding to exact outer circumference. but for this brand they are close. This belt of mine on the package is 54 and 3/8ths. but the important thing is the top width which is 12.5/13 mm so it fits our old pulleys very nicely.
The Napa 257535 fit, but it was on 10 mm wide and rode further down inside the pulley's. It would be harder to jump at 7500 rpm, but I think that the larger 13mm show above is much stronger. Because it rides out in the pulley it had to be longer.
Stock 79 l-82 lists the 257530 which is about a 1/2 inch shorter
Just for reference, on my 80 L82, I used a Continental Elite 17551 for the AC and 15542 for the Alt.
Here are the specs for the 17551
Belt Top Width (in) 0.531 Belt Top Width (mm) 13.487 Belt Effective Length (IN) 55.100 Belt Effective Length (MM) 1399.540
and for the 15542
Belt Top Width (in) 0.469 Belt Top Width (mm) 11.913 Belt Effective Length (IN) 54.200 Belt Effective Length (MM) 1376.680
Both at Rock Auto - sit down for the pricing: $1.48 and $2.13. They are listed as wholesaler closeout, but that's about the same price as I bought them for a year ago.
George, you were correct on the 530 being 53.0, that number is considered the effective length and was/is an industry standard. The belt profile (15, 17 and 22 common Auto Belts) indicated the top width in x/32's but various Mfg's. used there own prefixes in many cases. I like the dayco top cog belts.
Well that explains the numbers on the belts I used. Thanks,
Never liked how the alt stuck way the heck out there, always had some issue
3rd gen camaros have a nice setup, or swap to a long water pump where you can use short belts and tuck the alt closer in
