Gear vendor overdrive
Old Mar 13, 2020 | 06:29 PM
Gzilla's Avatar
Gzilla
Navigator
Default Gear vendor overdrive
In the middle of installing one now what a pain in the azz. Had to make new tranny x member and cut off about 2 1/2 inches of trail shaft output.and stock shifter isn't going to work also. Got a tci outlaw shifter. center console don't want to think about probably make custom with foam and fiberglass. Anyone have these problems also and others I can look forward to thanks
Old Mar 13, 2020 | 07:09 PM
riverracer au's Avatar
riverracer au
you don't say what year your car is, but no, have read many times they don't fit C3 without a crap load of work..
i just used a 700R4 in my '72
Old Mar 13, 2020 | 07:10 PM
Gzilla's Avatar
Gzilla
Navigator
Sorry 80
Old Mar 13, 2020 | 07:36 PM
Gzilla's Avatar
Gzilla
Navigator
Default Pics
haven't got to emergency brake either
Old Mar 13, 2020 | 11:02 PM
OldCarBum's Avatar
OldCarBum
I was seriously looking at installing a Gear Vendor Overdrive unit behind the TH-400 in my 73.
I gave up and went to a 5 speed manual.
The owner of Gear Vendor did install one in his early C3 and when I talked to him he told me all the work they had to do to get it to fit.
They had to, among other things, completely rebuild and widen the rear section of the tunnel so the unit would fit, which led them to modifying the seat tracks, then modifying seats so they could wedge them in to fit.
Gear Vendor will tell you it can be done but they will not recommend it.
Give them a call for what they did.
Good Luck.
Old Mar 14, 2020 | 12:32 AM
7T1vette's Avatar
7T1vette
Gear Vendors unit is the hard way to go. But, you are almost there. Once done, maybe you can give us your critique of that unit in a C3.
Old Mar 14, 2020 | 06:49 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I was thinking of going that way but couldnt find any info and then price scared me away. If you can keep posting up pics of your progress its going to help one of us further on down the road. Thanks for the pics so far. Nice welds on your crossmember!!! I ended up with a used McLeod 5 speed that I'm installing now
Old Mar 14, 2020 | 06:58 AM
roscobbc's Avatar
roscobbc
I'm intrigued- if the Gearvendors O/D unit is the generic modern version of the old school Hone-O-Drive product - how would have people like Baldwin Motion installed it in an early C3 Vette back in the day. Presuming it would have only been used on cars with Muncie transmissions?
Old Mar 14, 2020 | 11:36 AM
Gzilla's Avatar
Gzilla
Navigator
I'll take more pics still have to remove x member and paint. My friend had a small welder we just tacked it together and took to a professional welder. I should of used 1/8 inch but went with 3/16 2×3 rectangular tubing . I just bolted on the end plates and shimmied it up about 1/4 inch give me a little adjustment. Had to beat the tunnel a bit more than the guy at gear vendor told me . The seat tracks should be ok.
The price I didn't think was to bad about 2700 compared to good 700 about 1600 -2000 dollars + another 300-500 for torque converter
Old Mar 14, 2020 | 02:46 PM
7T1vette's Avatar
7T1vette
The GV unit is very expensive and the design is overkill for the purpose in most cases. It won't easily fit in a C3's driveshaft tunnel and it isn't a "seamless" product from an operational standpoint. It is still interesting to find how it fares in a C3 and whether it is viable as an alternative to an O/D manual or auto transmission. In terms of being able to keep the vehicle as close to original as possible, not sure how to judge that with another chunk of equipment in the system which requires body modifications.
Old Mar 14, 2020 | 04:49 PM
73C34me's Avatar
73C34me
Watching this closely! I would like to do the same install in my 73, which is already modded- originality doesn’t apply here.
Old Mar 14, 2020 | 07:01 PM
7T1vette's Avatar
7T1vette
The GV unit can handle a TON of torque. MUCH more than most C3's could ever dream to put out. Unless you are doing some mighty heavy 'pulling' with your car, it's doubtful that it's capabilities would ever be tested significantly. If they made a smaller unit for lower power, then it might be viable. Right now, the best choice for MOST folks is to install an overdrive manual or automatic transmission.
Old Mar 14, 2020 | 07:37 PM
roscobbc's Avatar
roscobbc
As good as aftermarket 5 and 6 speed transmissions may be (on late model cars) the ratios in most cases are optimised for best CAFE figures in late model cars (not 60's and 70's era cars). The lower gear ratios of late model transmissions may be perfectly suitable for smaller capacity and higher revving engines with limited torque at lower rpm. However first gear ratio's and the ratio 'spread' on the remaining gears (2nd, 3rd, 4th) is all wrong for the far wider torque spread of a big block powered vehicle.
For me the perfect transmission would be a M21 with stock ratios and a 30% or 40% overdrive 5th gear. Which is almost what a Gearvendors or Hone unit would provide.
Old Mar 14, 2020 | 09:29 PM
Rescue Rogers
I'ld love one if they were smaller
Old Mar 15, 2020 | 02:55 PM
7T1vette's Avatar
7T1vette
Piffle....
Old Mar 16, 2020 | 09:43 PM
7t9l82's Avatar
7t9l82
You turn your turbo 400 into a 6 ,speed in first shift into 1 overdrive shift into 2 then 2 overdrive etc.
Old Mar 16, 2020 | 10:30 PM
Gzilla's Avatar
Gzilla
Navigator
Or turbo 350 like mine
the manual has a page on racing they say you usually go from 1st -2nd-2nd over- 3rd and if you run out of gear overdrive .if your had a 700r4 you would probably hit 1st over because of the big drop.
To Gear vendor overdrive
