Echlin Condenser Part Numbers
Old Mar 15, 2020 | 08:47 AM
Elocma's Avatar
Elocma
Default Echlin Condenser Part Numbers
I'm replacing the points and condenser on my 72 small block and see two different Echlin part numbers - RR175 and RR1750. What's the difference between these? Part number for the points is CS786.
Old Mar 15, 2020 | 11:44 AM
jackson's Avatar
jackson
No, I don't know difference ... perhaps NAPA counterman does or NAPA tech ... or their maker Standard tech 718.392.0200
Have you considered a "uni-set" ? ... unitized point-condenser ? echlinblue streak standard ig pn DR-3575C
https://ecatalog.smpcorp.com/STD/#/v...R-3575C?type=s
FWIW, RR1750M has a brass case & terminal $$ (intended for marine use; marine bits typically more robust)
https://ecatalog.smpcorp.com/STD/#/v...RR1750M?type=s
http://www.kyptechline.com/
Old Mar 15, 2020 | 12:14 PM
MelWff's Avatar
MelWff
The Rr175 is twice the price of the rr1750, so for lack of anything else, i would go for the rr175
Old Mar 15, 2020 | 01:12 PM
lars's Avatar
lars
I use the RR175 in all my builds and tuning.
Lars
To Echlin Condenser Part Numbers
