Air intake
a Renegade Intake Manifold,? Don`t want to waste good money.
Our member here Buccaneer designed the intake......you might want to PM him or maybe he will pop in right here.
The intake is worth the expense and that is why Tom designed it.......to solve a huge problem with available flow.
Also, you do not want a polished intake.......a rough finish is desired to help keep the fuel suspended in the air.
Jebby
There are a few people on this forum mainly on the C4 section (rough crowd there) that will argue that you can port a stock manifold and get good performance. OK, that is a given with what the stock ports look like and you have the time and equipment to do the job correctly, but if you want a healthy boost in performance over stock, than the Renegade is the way to go. However, we pulled our tooling from the CA company manufacturing the manifold because they were doing a horrible job with the machining. There are a few available, but I wouldn't trust them to be machined correctly.
I'm in the process of re-manufacturing like new the original tooling by the original pattern maker in Phoenix right now. They should be done soon. Then I have to go back to the original foundry here in AZ to see (beg) if I can get it done there again at a reasonable cost. If that all works out, I have the original machinist that we used in the beginning who still has all the fixtures and CNC G-code to machine the manifolds again...correctly. A lot of IF's and Maybe's there that have to happen to start this process again.
So, I guess the choice is yours. Port yours if you want or wait and see what happens with the manifold. I do have two units here, one that is brand new, but needs attention and another that my machinist already fixed and is functional. PM me if interested and I will give you my number and we can talk.
