Advice needed pls!
Old Mar 18, 2020 | 11:23 PM
Charged 67's Avatar
Charged 67
Default Advice needed pls!
Hi,
I have a non runner and Im neck deep in bodywork! can someone advise how I lift the wiper arm cover in front of the screen?
Many thanks!!
Old Mar 18, 2020 | 11:29 PM
Dirty Dalton's Avatar
Dirty Dalton
On right side of firewall there is a 'drum' with rubber plug on front. Pop out the plug, and using suitable tool (sorry, can't remember, screw driver, socket extension) push thru hole. You'll be pushing against surface made to be pushed, shouldn't hurt anything.
Old Mar 18, 2020 | 11:40 PM
BarryB72's Avatar
BarryB72
I just blow into the red striped hose on the front of the actuator. Or if there's no hose I just blow/suck on the front nipple. Yep.
Old Mar 19, 2020 | 06:37 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
nope, I'm not saying it.....
Old Mar 19, 2020 | 08:54 AM
Charged 67's Avatar
Charged 67
Many thanks! been scratching my head for hours on this!
Old Mar 19, 2020 | 08:56 AM
Charged 67's Avatar
Charged 67
Thanks Barry. if option 1 doesn't work i will get on the nipple!
Old Mar 19, 2020 | 09:32 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Remove the screen and pull it up by hand? This is how I got my 72' frozen wiper door unfrozen......flipped it up and down a thousand times with spray on the pivots......it freed up and works as intended now.
If you are doing bodywork then you need to remove the metal vent for refinish anyway right?
Jebby
Old Mar 19, 2020 | 09:53 AM
kodpkd's Avatar
kodpkd
Just don't let your wife see you.
Old Mar 19, 2020 | 10:28 AM
BarryB72's Avatar
BarryB72
I was doing some work under there recently on the wiper safety switch and yeah, starting the car up every time got old fast.
So I got real good at it. And I'm fast too. She'll never know.
Old Mar 19, 2020 | 12:21 PM
Charged 67's Avatar
Charged 67
Yes agreed, I need to get the vent and cover prepped for paint but all screws are rounded off and I haven't hit an easy job on this car yet lol.... WD40 and elbow grease....
Old Mar 19, 2020 | 10:31 PM
Dirty Dalton
Charged - you will note that only one of the above explanations bears any semblance to the procedure written in the Shop Manual to accomplish your desired result.
To Advice needed pls!
