engine vacuum questions
Old Mar 19, 2020 | 09:58 AM
nearflack's Avatar
nearflack
Default engine vacuum questions
PO removed some/most of the vacuum lines now I have no idea what goes where. The 3 way connection at the intake is open at the top. I think that may go to the auto trans mission. I have also read there is a line to the cruise control. There is what appears to be a vacuum line that hangs down by the temp sender. It has a large end on it but very small opening deep in what looks to be a connector, almost like a spark plug wire but no wire inside just a hole, goes into the bundle with other vac lines. Many other electrical issues I am trying to chase down to. He had removed original breather which i have replace and am making vacuum line connections there. This is the last phase of a major rebuild. Looking forward to getting it road ready soon. By the way its an 1980 350 with cruise and auto transmission
Old Mar 19, 2020 | 10:26 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I would suggest you purchase one of these.....it is an invaluable tool for figuring out your 80'
The diagrams are all in there.
https://www.paragoncorvette.com/p-35...ly-manual.aspx
Jebby
Old Mar 19, 2020 | 11:14 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Jebbysan
...I would suggest you purchase one of these...
I agree. The AIM could be a big help for you.
Old Mar 19, 2020 | 11:32 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Docrebuild has some nice laminated hose diagrams. I got his electrical ones and they are invaluable.
To engine vacuum questions
