Help with possible valve issue
As per compression check, All Cylinders will read perfectly normal, all within 10PSI of one another. Sucking oil into the intake from the Valley Will make her smoke, but Valves and
Cylinder seal will be fine. Run the compression test, but all 4 on the right fouled like that doesn't really look like a valve lash issue.
I found that one of these vacuum gauges helped greatly for debugging and idle mixture setting, (along with a dial-back digital timing light).
Can you post a few over-all photos of your engine? The real engine gurus may be able to see something obvious.
1 - didn’t check
3 - didn’t check
5 - 183
7 - 180
2 - 0
4 - 0
6 - 0
8 - 40
i didn’t check 1 and 3 because they are a PIA and the plugs look good.
The engine is the original 350 stoked to a 383 bored 40 over with new aluminum heads, new cam, old performer intake, rebuilt carb, new HEI distributor, new plugs, new wires, new engine bay wiring harness to the starter, new starter.
Tgis engine is practically new, aside from the block and crank, which were both machined. What gives?
1 - didn’t check
3 - didn’t check
5 - 183
7 - 180
2 - 0
4 - 0
6 - 0
8 - 40
1) Head Gasket....which would have to be pretty bad to get zero on three and forty on one......like almost loose, head ready to lift off.
2) Rings.....again, the likelihood of one whole side being low is lottery odds.....the rings would have to be damn near gone.
3) Valves I or E......they could be bent and not closing or most likely, someone Bubba'd the valve lash when they did it.
Pull the passenger valve cover and look for any valves that appear to be open.....on a small block, it will be easy to spot, bent valves do not close........if they all appear to be closed then......go through and perform a full lash on all eight cylinders...here is a great article with contributions from the pros....Shaffiroff, Musi, and David Reher......nobody knows more about Chevrolet engines combined.
https://www.dragzine.com/tech-storie...sh-like-a-pro/
Once lashed......recheck your compression numbers.
Also...check one and three....if you do not then you do not know for sure.....don't discount those two cylinders because the other two on that side are ok....(180 is excellent). Incomplete data is incomplete data.
Jebby
Is this a flat tappet? Has the cam been broke in? If not......you need to pull the intake and all of the lifters to inspect.....I doubt you have run it 20 minutes for cam break in......do it now, or risk failure of the cam lobes. When the lifters are out.......mark the position of them, clean, and reinstall with some moly paste only on the foot of the lifter, not the sides......oil the sides and reinstall.......this will be the cost of time and an intake gasket to do and could save you hundreds.
Jebby
thanks everyone
Keith
I never went back to him to tell him the lifters were stuck, because I just wanted to move on. I try my best to think people are good and that it was an honest mistake and I just want to move on to the next project. Life's to short to stay mad.
So overall, the car runs much better. After getting the lifters replaced and updating the rockers, all ticking was eliminated from that area. Then I discovered some exhaust leaks that caused additional ticking. Corrected those. So slowly but surely, getting this engine right. Just replaced valve cover gaskets this past week to eliminate some leaks. This has been the longest engine rebuilt project ever.
Keith
