Rebuilt MC, Now Big Problem
Old Mar 21, 2020 | 03:35 PM
revitup's Avatar
revitup
Whatever the issue was, it's gone. Reinstalled the rebuild kit, took it for a test drive. Brake warning light was on when I first started it but went out with a couple of pumps on the brake. Leak seems to be fixed (the reason I rebuilt the MC in the first place). Brakes are working perfectly. Thrashed it a bit, hard pedal, sure stops, easily lock up those 'big' 255-60s. Happy that it's fixed but not so happy that I don't know what the problem was. Stuck proportioning valve, trapped air, flipped piston lip seal, no idea.
Thanks to everyone that contributed ideas.
Old Mar 21, 2020 | 06:56 PM
HeadsU.P.'s Avatar
HeadsU.P.
Originally Posted by revitup
I'm thinking that gap is necessary with the lip seal design to allow fluid to get behind the lip.
I do wonder if it's possible that one of those lip seals could 'flip' as the piston is being pushed into the bore on assembly. Doesn't seem likely though.
I agree about the Lip Seal style. I do know that the "O" Ring style will flip itself over and damage itself on the return stroke of the brake pedal. Hence, on the box of a new MC is a bright red label stating: Do Not Force Piston Into Bore, More Than 1 3/8" or you will void the warranty.
Old Mar 21, 2020 | 07:00 PM
HeadsU.P.'s Avatar
HeadsU.P.
And here is the worst part, billing.
Case; revitup
Issue: MC woes.
Outcome: resolved
That will be $119.
How do wish to make your payment?
Old Mar 21, 2020 | 07:15 PM
revitup's Avatar
revitup
Case; revitup
Issue: MC woes.
Outcome: resolved
That will be $119.
A 36-pk of TP? Divide it amongst yourselves as you see fit.
Old Mar 21, 2020 | 07:25 PM
HeadsU.P.'s Avatar
HeadsU.P.
Mega rolls only please. If its white tissue, I can color it.
Old Mar 22, 2020 | 03:23 PM
righthanddrive's Avatar
righthanddrive
That's what I like about the fellow C-3 owners. Everybody seems to have a good sense of humor , willing to give advise ,and not be A**holes with nasty comments.
