distributor stop bushing
Old Nov 21, 2002 | 06:58 PM
BEZ71's Avatar
BEZ71
Default distributor stop bushing
has anyone removed their stop bushing from their distributor . if so how does it run i was told it's ok to run without it. thanks
Old Nov 21, 2002 | 08:43 PM
WATTAC's Avatar
WATTAC
Default Re: distributor stop bushing (BEZ71)
What part are you calling the "stop bushing"? Where is it located?
Andy
Old Nov 22, 2002 | 11:17 AM
Desertvette's Avatar
Desertvette
The bushing is there to take the wear instead of the plate slot. I asume your talking about the pin and bushing on the bottom of the distributor shaft to limit mech advance.
If your wondering how your engine will run with additional mech advance ,it would,nt hurt to remove temporarily, but once you figure out what you want for total mech advance open up the slot the bushing rides in for permanent setting. The bean counters at GM don't let the engineers install extra parts just for the heck of it.
If it's installed it's for some purpose.
Bob
[Modified by Desertvette, 11:00 AM 11/22/2002]
Old Nov 22, 2002 | 11:44 AM
redvetracr's Avatar
redvetracr
I always use a "stop bushing" you might replace it with a metal one but I think it is there to limit the amount of total advance. ...redvetracr
To distributor stop bushing
