Sniper and ground wires.
Old Apr 2, 2020 | 08:02 PM
flyeri's Avatar
flyeri
Default Sniper and ground wires.
Well it has been a while since I started on my Sniper install on my 68 with a ZZ454. I moved fuel pump relay to the battery box and trigger the pink wire through a relay (also in the battery box) connected directly to the battery. 12 gauge + and - main power wires are connected to the battery also. I have braided metal shield over power and ground wires and a separate shield over the pink wire. These are grounded directly to the battery. I have routed all wiring is as far as possible from ignition wires. All of this in an effort to eliminate electrical noise. I have paid very close attention to the battery to frame ground wire and actual connection point as well as the frame to engine ground. I am going to add a direct alternator to frame ground. For those who have installed the Sniper, have you found that other grounds are needed? Any other advice before I finish up and try the first start?
Old Apr 3, 2020 | 09:40 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Where the control wiring to the ECU comes in close proximity with the spark plug wires is a source for radio interference. T
Old Apr 3, 2020 | 09:45 AM
jimco84x's Avatar
jimco84x
2019 C3 of Year Finalist (track prepared)
It sounds like you have all the bases covered. I'm assuming that based on your thoroughness, you also used high quality connectors for the few wire splices that were necessary. Good connections, proper grounds and proper wire routing is critical. With all that, it should be trouble free.
Old Apr 10, 2020 | 09:22 AM
flyeri's Avatar
flyeri
Just a quick follow up. Yesterday I finished the install and attempted the first start. Fuel pressure was a solid 60 psi and I had no leaks. After running the wizard I turned the key and it fired almost instantly, but died. I tried this a couple of times with no start. I checked the No Start flow chart and while looking at the gauges I realized I was getting no tach signal. Found the connector on my HEI had come loose. After reconnecting, it started immediately. I had to make an adjustment to the throttle adjustment screw. After it warmed up I reset the IAC as directed. I drove it for about 15 minutes and am happy to report that it ran great. Throttle response was crisp, acceleration was smoother. The best thing was that when I pulled back in the garage my wife said it didn't stink like it used to. So far I'm thrilled with the Sniper.
Old Apr 10, 2020 | 10:26 AM
derekderek's Avatar
derekderek
New fuel feed line? I feel the 50 year old fuel line designed for slight vacuum is not a good candidate for 60 psi fuel feed. It is fine for a return line, but if it leaks, it sprays fuel all over the exhaust at 60psi while still runs. If same line leaks while feeding an engine mounted fuel pump, carb sucks air instead of fuel and engine stops.
Old Apr 10, 2020 | 07:50 PM
flyeri's Avatar
flyeri
Yes I did install new fuel lines. Some suggested that the fuel injectors issues may be caused by crud inside the old metal lines. I wanted no problems so I cut out the old and plumbed new. I was worried about possible leaks as you describe. The old fuel line did have crud, corrosion, etc. inside so I think it was a good call. With the hose and two new hose ends it added about $125 to the job. Not bad for peace of mind.
To Sniper and ground wires.
