Where to mount an MSD box
Old Apr 2, 2020 | 08:56 PM
7t9l82's Avatar
7t9l82
Default Where to mount an MSD box
Where have you guys mounted your MSD boxes I don't have wiper arms on the car because I don't drive it in the rain and I keep rain x on the windshield so I'm wondering about there or behind the glove compartment.
Old Apr 2, 2020 | 09:16 PM
69ttop502's Avatar
69ttop502
I have no heater so mounted it there. Before that I had it mounted just above the washer bottle in passenger fender. Have also seen a few under the parking brake console and in the nose of the car.
Old Apr 2, 2020 | 09:38 PM
7t9l82's Avatar
7t9l82
I'll have to check some of those places. Not alot of options really .
Old Apr 2, 2020 | 10:16 PM
Mooser's Avatar
Mooser
A handful of ideas here
https://www.corvetteforum.com/forums...-so-where.html
mine in the passenger fender behind the grill so it's easier to get at
M
Old Apr 2, 2020 | 10:26 PM
jackson's Avatar
jackson
They generate heat & they like some air flow. Some are sealed to weather, thus are more flexible as to placement; most CT cars have em atop dash ... some on tunnel.
When CD boxes fail, you're dead in the water ... reason CT, RR cars often run a switchable pair of boxes w/ two coils & a dual-pickup dist. ... essentially a redundant system ... boxes fail.
The more robust boxes' circuits are potted in a thick urethane which helps dampen vibration & functions as a heat sink.
Don't recommend them for a street car. Have a spare matched MSD HVC box & coil ... from one of ill-fated driver Jerry Nadeau's old cars. Poor fellow, TBI.
Old Apr 2, 2020 | 10:53 PM
7t9l82's Avatar
7t9l82
I wanted a crane box, I thought FAST had bought them but I wasn't sure I got a deal on a 6 AL . I like the wiper well. I think that's the easiest and certainly accessable. I wonder if they have a way of dealing with jump starting.
Old Apr 2, 2020 | 11:43 PM
akdale's Avatar
akdale
Well, I don't use the storage so its in the box next to battery. I have checked and it's never too warm (6AL-2 Programmable).
Old Apr 2, 2020 | 11:54 PM
Eliredandblack's Avatar
Eliredandblack
I removed the charcoal canister since all the emission equipment was removed, and mounted it to the wheel well. Purchased a set of additional rubber stand-off / insulators so the unit would be held in place on each corner. The cables were long enough so I didn’t have to spice the cables from the MSD Control.
Old Apr 3, 2020 | 07:15 AM
69ttop502's Avatar
69ttop502
Check out this link comparing boxes. I have the Daytona sensors unit. I love it.
http://www.4secondsflat.com/CD1-MSD-...Comparison.htm
Old Apr 3, 2020 | 07:25 AM
7t9l82's Avatar
7t9l82
Mounting in the storage compartment is more wiring than I want to get into, but probably is a good location.
the daytona sensors unit is much more than I need, at least for now.lots of nice features
Old Apr 3, 2020 | 08:01 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I mounted mine in the passenger side fender where the washer bottle would have been. It gets airflow as the air moves out the side vents. It is also a pretty easy location to reach.
Old Apr 3, 2020 | 01:25 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
mines behind the passenger dash pad up high where the radio amp was mounted from the factory. Its a short route to the dizzy and plenty of area to hide the wires.
where the wiring comes through the wall
I mounted it upside down to get the plug on the left so I could unplug it easily if I had to weld on the frame to protect it
Old Apr 3, 2020 | 02:02 PM
CAMS69's Avatar
CAMS69
Default here
69 coupe with vintage air...built a beocet and attached to the two studs for the oem a/c box
Old Apr 3, 2020 | 04:04 PM
carriljc's Avatar
carriljc
Mine is in about the same place. I have Hot Rod Air.
Old Apr 10, 2020 | 09:04 PM
68vette2go's Avatar
68vette2go
Mine is in the same general location. We put the MSD box, trans controller, radiator overflow and six relays for the EFI, in this location. Actually added a catch can yesterday also. Area is about to capacity now! Wanted to maintain that clean “old school” look under the hood.
Old Apr 10, 2020 | 11:53 PM
txfatboy1's Avatar
txfatboy1
I no longer have vacuum headlights or wiper door so I was able to remove the massive vacuum canister. Then I made a platform and mounted my 6AL with the rubber feet to minimize vibration.
To Where to mount an MSD box
