1972 350 AC compressor pulley diameter?
Old Apr 6, 2020 | 03:43 PM
Jhiltonn's Avatar
Jhiltonn
Default 1972 350 AC compressor pulley diameter?
I’m looking at replacing my AC compressor (model A6) but I need to know what the exact compressor pulley diameter is for a 1972 corvette with 350 engine 4 speed. Does anyone know exactly for sure? I’m seeing pulleys with 4.870” dia., 5.12” dia., , and 5.00” diameters so I want to be sure to order the correct one. I’m confused as each vendor on eBay says their compressor is 100% compatible. Thanks everyone!!
Old Apr 6, 2020 | 04:06 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
My original '72 A6 compressor's pulley diameter is 5.125 across the rim.
Old Apr 6, 2020 | 07:17 PM
Jhiltonn's Avatar
Jhiltonn
Thank you sir!! Do you have a 350 or 454 engine?
Old Apr 6, 2020 | 10:25 PM
barkingrats
Apologies, mine's a 454. As I read my Chev. parts book ('53-'79) they all used the same compressor unit from '66 to '76 and clutch coils from '62-'78. The pulles were different though and for the 350 in '72 should be #6550482. You can see the listing here: http://www.gmpartswiki.com/getpage?pageid=89195
Unfortunately they don't provide a diameter and the pulley was discontinued in '80 or so.
This NCRS thread may hold the key to what you're after:
A6 pulley size conclusion
To 1972 350 AC compressor pulley diameter?
