temperature gauge
Old Apr 7, 2020 | 03:11 PM
ray3222's Avatar
ray3222
Default temperature gauge
Had fluctuating temp gauge. Replaced sending unit. Worked & read 180 degrees. However, on excessive idle(food drive thru), the needle registers to the far right with engine running normal temp. Any suggestions? Thanks.
Old Apr 7, 2020 | 03:19 PM
jim-81's Avatar
jim-81
Are you sure you aren't low on coolant?
Old Apr 7, 2020 | 04:08 PM
carriljc's Avatar
carriljc
Check the tightness of the connections in the back. Mine was acting similarly shortly after I had reinstalled it.
To temperature gauge
