MSD 6A digital.
Old Apr 9, 2020 | 07:32 PM
7t9l82's Avatar
7t9l82
Default MSD 6A digital.
I just got an MSD box and installed it. I haven't installed one in about 35 years. On an HEI it's almost plug and play.the new digital box has one big plug. So I mounted the box and left the plug free of the box.the instructions say to disconnect the battery which I didn't do I just wired it up and plugged it in and it worked perfectly as I thought,except the battery was slam dead for some reason.msd says disconnect the battery Yada Yada yada, well, I unplugged the box and put a battery charger on it and guess what, it worked perfectly,no.suprise to me.
I didn't expect any power increase, that's not how these things work but I recently installed a pretty hefty cam and it does seem to make it idle a little better without loading up nearly as much and it does seem like it helped ar higher RPM .I'm not saying everyone needs one, but I think the HEI isn't really suited for much over 9-1 compression it's starting to struggle and. About 400 RPM it gets a bit weak. It really was designed for weak smog motors and not a high performance ignition. I'm sure somebody will banter on about it. But I'm very pleased.
Old Apr 9, 2020 | 07:43 PM
jackson's Avatar
jackson
Banter ... good HEI is good for 10:1 + at sustained race rpm.
To some degree, sure CD ignition does helps light off richer mixtures. You'll probably like it, until ...
Old Apr 9, 2020 | 08:14 PM
7t9l82's Avatar
7t9l82
Well a magneto was my first choice
Old Apr 9, 2020 | 08:24 PM
Big2Bird's Avatar
Big2Bird
As Jackson stated, MSD is useful at idle for engines operating abnormally "fat."
Above 3500 RPM, it does jack ****.That is when it "bypasses." I have observed misses at this transition.
The only other car I can think of that used multi spark was the Model T Ford. Quite useful back when gasoline was horrible.
I do not believe any automobile manufactured in the world uses that tech.
HEI works just fine at higher compression. Coil packs eliminated the "dwell/coil saturation" issue.
Old Apr 9, 2020 | 08:35 PM
7t9l82's Avatar
7t9l82
The multi spark only works to about 3k RPM's after that it's a capacitive discharge ignition.your right no auto manufacturer uses it because they have a coil on every plug.. they aren't dealing with an ignition designed in the mid 70',s. I see lots of MSD boxes at the drag strip and on some pretty fast street cars, I don't suspect it's because we are all stupid.
Old Apr 9, 2020 | 08:49 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I've got he 6AL digital as well. It works great!!
Old Apr 9, 2020 | 08:58 PM
jackson's Avatar
jackson
IMO, the "when" is of no consequence ... But seems both GM HEI & ACC/MSD multi-spark CD boxes have a Seventies footing.
Old Apr 9, 2020 | 09:26 PM
Big2Bird's Avatar
Big2Bird
Look, I am not judging here. Just stating facts and experience.
Everything is a trade off in electrical.
Spark "Energy" is the key.
The only ignition that gets "hotter" with speed is a magneto. Check your drag cars again. They all run 2., just like an airplane.
Like an airplane, failure is not a good thing.(Crash/explode).
NASCAR uses them for fat mixtures at low speeds. (Notice, there are always two. They are also NOT your box at Summit. Hand made.
Will they work on a street car. Absolutely. Are they reliable? Well.............
All these speed part people are all corporate owned. Hype is king. Read a 1919 Western Auto Catalogue, still in print, and you will find the "soup de jour" speed parts of the 20's.
The Kettering design is really old, and sometimes it's improved, but always uses inductors.
Inductors, (transformers), out live Caps . Reliable, steady, repeatable, results. It's just how it is.
Rambling over. I could go on 2 hours on the right day,.
Old Apr 9, 2020 | 09:29 PM
Big2Bird's Avatar
Big2Bird
One was designed by a Corporate giant.
One was designed by an independent engineer.
(Not Steve jobs garage).LOL
Old Apr 9, 2020 | 09:36 PM
jackson's Avatar
jackson
http://delcoremyhistory.com/history.htm
interesting read ... check year 1966
Old Apr 9, 2020 | 09:45 PM
Big2Bird's Avatar
Big2Bird
I want to spew one more thing.
I am a retired electrician. NOT an engineer.
My father was a Chief in the Navy.
He was an aviation ignition specialist. Worked on corsairs and such, and taught aviation ignition on a secret Naval Base in Enid Oklahoma.
I still have his teaching notes. He taught me at age 13.
I just have a different "skew" on ignition designs.
They are just reusable blasting caps. (Wait for that rebuttal).LOL
Old Apr 10, 2020 | 09:51 AM
7t9l82's Avatar
7t9l82
I thank your Dad for his service to his country,My dad was a decorated Combat Engineer in both theaters in WWII.. THANK YOU FOR YOUR INSIGHT ON THE SUBJECT! It will be given the appropriate consideration.
Old Apr 10, 2020 | 10:59 AM
Big2Bird's Avatar
Big2Bird
Thanks Jack. 1953. Always wondered when the Anaheim battery plant was built.
I worked out there once on top of their water tower in a light rain. NOT fun at all. About 1984 or so.
Old Apr 10, 2020 | 01:42 PM
jackson's Avatar
jackson
Did you see this pic of plant 13 ? Is that your perch at far right ?
Old Apr 10, 2020 | 03:51 PM
Big2Bird's Avatar
Big2Bird
Yes sir
The brand new Interstate 5 is at the bottom of picture.
Old Apr 11, 2020 | 08:57 AM
stingr69's Avatar
stingr69
That new cam has a good bit of overlap event from the 110 lobe separation angle and quick ramps. The extra help from the ignition will make it start easier and idle cleaner/better. Improvement enough there.
Old Apr 11, 2020 | 10:26 AM
jackson's Avatar
jackson
Funny ... I KNOW a couple sandlappers who worked w/ South Coast Electric during Wendy's big SoCal expansion
To MSD 6A digital.
Old Apr 11, 2020 | 10:40 AM
Little Mouse's Avatar
Little Mouse
Lol sounds like the HEI with no more coil help cant even get the job done at idle much less 4000 rpm or high compression engines It did not get used on. Lol. Corporate giant that its stock went to 85 cents and government receivership from making bad products and its customers simply went to Japan for there cars. Lol I could have bought a lot of that 85 cent stock and been a bit on the rich side today after the government got rid of there people and put others in charge of gm. Italian corporate giant fiat bought chrysler.
Old Apr 11, 2020 | 11:42 AM
Big2Bird's Avatar
Big2Bird
I suppose after the race, when you get your azz beaten down, you can always say "But mine idles better."
Old Apr 11, 2020 | 11:45 AM
jackson's Avatar
jackson
