Door won’t open
Old Apr 11, 2020 | 09:32 AM
SummerOf77's Avatar
SummerOf77
5th Gear
Default Door won’t open
I have a ‘77 that the passenger side door will open from the outside but not from the inside of the vehicle.
Again, new to working on these so any help is very much appreciated on where to start.
Old Apr 11, 2020 | 09:44 AM
kansas123's Avatar
kansas123
When the door is open and you fiddle with the inside handle, do you hear anything or feel any resistance? Nothing moves in the latch area? You will probably have to remove the door panel to get a look inside, it might be something quite obvious in there that you will see right away. Take the panel off and post pictures.
Old Apr 11, 2020 | 09:59 AM
HeadsU.P.'s Avatar
HeadsU.P.
Go to YouTube and type in: C3 Door Handle Repair.
Then you can get a visual of what's going on inside the door. Take note of the small parts, clips, clamps, etc on the door rods. Those small parts can be found on EBay for a song, free shpg.
kodpkd's Avatar
kodpkd
What he said, but you might play with the latch post on the door sill. You can loosen it with an allen wrench and move it just a bit in or out, tighten it, and see if helps.
Old Apr 11, 2020 | 08:33 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'm thinking that if it opens fine from the outside. Fiddling with the latch is truly a waste of time. Perhaps one of the clips on the rod popped off and the inside lever is just disconnected. You need to get that door panel off.
Old Apr 17, 2020 | 10:09 PM
SummerOf77's Avatar
SummerOf77
5th Gear
Going to be changing out all the weather stripping within the next week so I’ll pull the panel off then and check out how it looks
To Door won’t open
