Carbless start
Old Apr 13, 2020 | 03:26 PM
Adam Lawrence's Avatar
Adam Lawrence
Default Carbless start
Hello all!
I removed my carb over the weekend on my 1977 C3 Corvette to have it rebuilt. I put a rag into the intake opening and closed the hood. Well, this morning my roommate tried to start my car to move it (not knowing that I removed the carb), needless to start it didnt start. The fuel line spray fuel everywhere, outside of that, the rag i stuffed into the intake opening might have prevented any unwanted particles or fuel to enter the crank case... How worried should I be?
Thanks for your help.
Old Apr 13, 2020 | 03:42 PM
Adam Lawrence
I should also note, I remember seeing little shavings from the carb gasket inside the manifold once I removed the carb. I figured I would have vacuumed those out later. Now that the engine has been turned over a few times, those are certainly now inside of the crank case.... Will those burn off or do I need to take the whole thing apart and remove them?
Old Apr 13, 2020 | 03:45 PM
mysixtynine's Avatar
mysixtynine
The fact that you had the mind set to stuff a rag in the intake tells me that you were careful not to leave anything there to fall in in the first place.
I'm sure your fine.
The bits of cardboard like gasket material should not really be a concern. If you left nuts, bolts or small brackets in there then... welll.... At this point .. theve wind-milled through already.
NOW... what else of yours is your roommate touching... that's what id be worried about?
Next time.. pull the negative terminal off the battery before you leave it like this so no one can play with your stuff.
Old Apr 13, 2020 | 03:50 PM
MelWff's Avatar
MelWff
For future reference, disconnect the battery
Old Apr 13, 2020 | 04:02 PM
Adam Lawrence
Thanks for your replies (and peace of mind)! Yes I should have disconnect the battery!
The next thing my roommate will be touching is his wallet (should this cause any problems) : )
Old Apr 14, 2020 | 08:10 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I am surprised it didnt suck the rag into the valves. I agree, I wouldnt worry about some cardboard gasket and depending on how much he cranked it its all gone. If you were curious you could pull the plugs and low some air in there and see if anything blows out but again, its not worth the effort. Good thing the gas didnt ignite.
I agree with pulling a battery cable or locking the keys in the tool box where you can find them again but wont start the car from in there
To Carbless start
