Driveshaft balancing
Old Nov 23, 2002 | 11:38 AM
noskillz's Avatar
noskillz
Default Driveshaft balancing
Where corvette driveshafts balanced in 1969? The shaft is pretty short so I am not sure it is required or make much difference. Either mine wasn't or it has thrown the weight.
Old Nov 23, 2002 | 11:45 AM
vettfixr's Avatar
vettfixr
Default Re: Driveshaft balancing (noskillz)
I believe all driveshafts were balanced but the half shafts weren't. I might be wrong on this.
Old Nov 23, 2002 | 12:25 PM
Gordonm's Avatar
Gordonm
Default Re: Driveshaft balancing (vettfixr)
Yes the driveshafts were balanced. After 30+ years the weights might be long gone. I would have it rebalanced. The half shafts are not balanced due to much lower rpm then the driveshaft
To Driveshaft balancing
