My '77 Passes CA Smog!!
Old Apr 24, 2020 | 01:21 PM
Shark Racer's Avatar
Shark Racer
Originally Posted by Jim__H
Right you are Jake.The standards get tighter and tighter so I am told so good move getting a '74. It's been a while but I recall getting a mailing or two from the state offering me money to take the car off the road. I don't recall a dollar amount but I'm sure it wouldn't be anywhere close to what I have into it. I think the cars between 1975 to when they started putting ECUs in are the hardest to keep legal. Heck, I love a good challenge (insert masochist emoji here)
I have all my smog tests over time and you can see the limits dropping, which is simply ridiculous.
Having tried to keep a 78 and an 87 Corvette on the road, I can say that the 78 projects to be much easier. Mechanical smog controls, no matter how stupid they may be, are far more prolific. By the 80s when some cars were getting port EFI, some getting throttle body EFI and some sticking with carburetors, parts became far more specific and electronics integration started to happen. There were quite a few smog parts for that car that no longer existed in a new off-the-shelf SKU I could buy.
The 70's stuff crosses a lot more vehicles and many of those parts carried into the 80's for the TBI and electronic carbed vehicles. Not to mention, if something isn't QUITE working right, you won't hit a CEL which is an instant-smog-fail in an EFI vehicle, even if the tailpipe numbers work out.
Old Apr 24, 2020 | 03:55 PM
Jim__H's Avatar
Jim__H
Ok, I'll buy the point that the 80s cars are a bigger challenge than the later 70s. I'm not familiar with them but it makes sense. As for the state tightening requirements they just want to get these cars off the road, what do they care whether we like to drive cool old cars or not? If I get another one of those buyback notices I'll share it with the group.
Old Apr 25, 2020 | 01:57 PM
JakeLucas's Avatar
JakeLucas
We’re car lovers. Most people don’t care much about their cars. They just want to get from point A to point B. I’m fine with getting old crap-boxes off the road that no one cares about.
It’s a shame that it’s so difficult to keep vintage cars that people love passing, while they continually raise the bar, making it harder and harder to pass.
Those of us that care about this and other car related issues, that haven done so already, can check out this link.
https://www.semasan.com/legislation
Old Sep 19, 2020 | 05:32 PM
igilbert91's Avatar
igilbert91
It's stock Y-cat-Y, any diversion from that would fail visual. Although I do know some have gotten away with dual exhausts/2 cats in CA but I didn't want to push my luck.
Jim - when you dropped the headers into the car, did you have to cut the front Y pipe short to accommodate the longer headers? I want to replace my exhaust from manifold to tip, but need to pass smog as well, and thus need the Y-cat-Y setup. Thanks!
Old Sep 19, 2020 | 08:07 PM
Shark Racer
Exhaust work is required to fit the y-pipe to any long-tube header.
If performance is your goal, long-tube headers are the answer. They will wake up any C3 engine that’s using stock manifolds.
Old Sep 19, 2020 | 10:17 PM
Jim__H's Avatar
Jim__H
igilbert91, if you live in CA the only legal headers with an EO # are Hedman 68301 and as Sharkracer says custom exhaust work is needed to get both sides to the cat. My left side travels down the length of the transmission pan (700R4 upgrade) and then a sharp bend around the pan to a Y and then to the cat. Also, and this may or may not apply to you, locating the EFE is a challenge. As luck would have it the Hedman's are tighter on the right side than the left and I had to mount it on the left side. One smog guy (who was a jerk) would not smog the car because of that. The guy who did smog the car, not a jerk, never mentioned it.
Good luck!
Old Sep 20, 2020 | 12:58 AM
Tranz Zam's Avatar
Tranz Zam
I feel bad for you guys that need to deal with that crap.
Old Sep 20, 2020 | 10:44 AM
ramair_bryan's Avatar
ramair_bryan
Help me understand...............
Heads, intake, headers, all have an EO #?
Or no. and the smog dude passed the you the vis anyway.?
Just to be cool with your smog guy, erase the report here.
Just in case.
No address, name , shop # etc...
(Well done by the way).............
Old Sep 20, 2020 | 02:14 PM
Shark Racer
Just in case.
Everything the smog guy checked on my car and Jim’s have EOs. His build is very similar to mine, I am using the next rev of AFRs and a Dart 400 block, along with a mild roller cam with negative overlap and about an extra point of static compression ratio.
Old Sep 22, 2020 | 01:42 AM
Jim__H's Avatar
Jim__H
My smog guy verified the EOs for the cat, headers, and heads. The last two are the obvious mods, even though there were EO stickers on the firewall. He didn't ask about anything else.
