Resetting the dash brake light?
Old Apr 22, 2020 | 01:11 PM
danh77's Avatar
danh77
Default Resetting the dash brake light?
I had a leaking caliper issue over the winter and the subsequent p.i.t.a. brake bleeding dilemma which I searched the forum and posted questions and got good info and advice and now have no more leaks and a pedal that is solid and honestly better than since I’ve owned it. My question is this, the light on the dash, from what I’ve had suggested and searched the valve needs re centered but if this the issue why would I be able to bleed all 4 wheels. What I read suggested that if the valve senses a imbalance it shuts off the affected circuit and prevents complete brake loss. I did unplug the switch at the block just to verify and yes the light goes out. Would this be indicative of a bad valve or is it possible I still have air trapped in the valve? When I bled everything I did hit the calipers with a rubber mallet but never tapped this distribution block/valve deal. I’ve also tried the stabbing the brake pedal deal to no avail.
Old Apr 22, 2020 | 01:17 PM
Bergerboy's Avatar
Bergerboy
Not sure about '77's, but my understanding of the valve in general (and for my '69) is that it should be reset by a hard and fast several stomps on the brake pedal after the system has been fully bled and topped off.
This "should" re-center the valve pin inside the valve body and allow the light to turn off.
Old Apr 22, 2020 | 03:12 PM
danh77's Avatar
danh77
Do you know if stomping the pedal is done with it running or not?
Old Apr 22, 2020 | 11:19 PM
speedreed8's Avatar
speedreed8
I did this recently on my 79 after bleeding brakes. Stomped the brake pedal very hard 5 times with key on , engine not running. Light turned off.
Old Apr 23, 2020 | 12:32 PM
danh77's Avatar
danh77
Ok for what’s its worth in my case I tried the key on engine off deal and didn’t work. What did solve it was car running pressed the brakes like a normal stop and held it there for maybe 10 seconds and light went off.
Old Apr 23, 2020 | 12:36 PM
Bergerboy's Avatar
Bergerboy
I'm guessing you've got power brakes then?
Engine running charges the booster for more oomph out of the pedal.
If manual brakes, engine running shouldn't matter.
But good on'ya for the fix!
Replacing that valve would have meant cracking open the fluid system again and re-bleeding.
Old Apr 23, 2020 | 12:57 PM
7T1vette's Avatar
7T1vette
Engine running with power brakes. And you really need to stomp hard and fast several times to re-center that valve. There is a tool for recentering that valve, once you remove the sensor from that distribution block. But, as you have said, it will then require re-bleed on the brakes. Good luck.
P.S. You can bleed the system with that valve off-center. It just flows more slowly. When repairing the brake system for a leak, it is best to re-center that valve BEFORE doing the bleeding process. Not something we normally think of, however.
P.P.S. You are aware that the e-brake, when engaged, also turns on that same BRAKE lamp. Hopefully, you don't have the e-brake engaged....
Old Apr 23, 2020 | 01:09 PM
HeadsU.P.'s Avatar
HeadsU.P.
The little tool that centers the Prop Valve piston when bleeding brakes for when using the "pedal method". Removing the switch (sensor) does nothing to the brake system.
No fluid will come out of the Prop Valve switches port, nor will air go into the Prop Valve. So no bleeding is require to swap-out the switch or remove the tool.
If the warning light refuses to cancel, and you have a good pedal, then suspect the little spring in the Prop Valve is on its last leg. Rare, but does happen.
And on occasion, the switch itself is shot. Those switches have different designs over the yrs. Make sure you get the correct one.
Old Apr 23, 2020 | 01:29 PM
danh77's Avatar
danh77
I knew the e brake wasn’t on as that was one of the first things I checked. I guess this must have been one time where I got very lucky, it didn’t require stomping hard or fast, I literally just pressed the pedal like I was making a normal stop and held it for maybe 10 seconds and it went out.
Old Apr 24, 2020 | 12:00 PM
nearflack's Avatar
nearflack
Had similar issue. Brake warning light was on and would not go off after trying the methods discussed above. Power bled all calipers again and light went out after starting engine and applying normal pressure to the pedal a few times. I actually heard the piston when it released and the light went out.
Old Apr 24, 2020 | 12:39 PM
7T1vette's Avatar
7T1vette
To Resetting the dash brake light?
