Front sway bar spacers
Old Apr 26, 2020 | 04:01 PM
VettedGood's Avatar
VettedGood
Navigator
Default Front sway bar spacers
I finally managed to squeeze my Dewitts radiator into my 80 and it looks like the lower hose mount is probably 1/16th of an inch away from the front sway bar. Does anyone make a spacer that will drop the front sway bar down? I think I have the Gymkhana suspension, so it’s got the bigger sway bar up front. Or is there a decent after market bar that drops down or is smaller in diameter that won’t significantly impact handling? Hard to see from the below photo, but I can barely get the hose over the fitting...
Old Apr 26, 2020 | 05:02 PM
ignatz's Avatar
ignatz
Any 1/4" spacer under the mounting bracket should do the trick. Nylon or aluminum or anything you can fab from that doesn't compress.
Old Apr 26, 2020 | 05:15 PM
interpon's Avatar
interpon
My dewitts universal in 79 is the same..i don’t have larger sway bar i have the 15/16 one..and its close
Old Apr 27, 2020 | 05:46 PM
bazza77's Avatar
bazza77
I made some from aluminium , just take the bracket off and trace the contact area , drill 2 holes and cut it out , file the edges if your keen enough !
Old May 10, 2020 | 01:34 PM
interpon's Avatar
interpon
@VettedGood what did you do? Make a spacer? Im in same boat coming up..
https://www.corvetteforum.com/forums...-size-etc.html
To Front sway bar spacers
