1972 Fusable Link
Old Apr 27, 2020 | 03:32 PM
70s Vette Guy's Avatar
70s Vette Guy
Default 1972 Fusable Link
I have a fusible link on my 72, location between my distributor and wiper motor. I am looking to replace it, but having trouble finding one. Any ideas?
Old Apr 27, 2020 | 03:55 PM
Tampa Jerry's Avatar
Tampa Jerry
NAPA has a full selection of them. Jerry
Old Apr 28, 2020 | 09:51 AM
7T1vette's Avatar
7T1vette
If you can't find a properly made fusible link, you need some wire two awg sizes smaller than the wire to which it is connected, with non-flammable insulation (teflon?) and some JB Weld putty epoxy for putting a big bead of epoxy on the connection points between the fusible link and the regular wiring. Then the link can fry when it fails, but NOT start an insulation fire. Fusible links should NEVER fail...except when an electrical device it is protecting causes an electrical short (or an owner does so by leaving power connected to the car when doing electrical work ). Eventually, old age may take its course with fusible links and they may need to be replaced, as a result. It seems that age is somewhere around 40 years.....
Old May 1, 2020 | 12:10 AM
croaker's Avatar
croaker
JB weld takes place of the little barrel thing?
Old May 1, 2020 | 01:20 AM
70s Vette Guy
Default Fusible Link
I was thinking of taking the fusible link off my son’s 74 donor car, looks the same. It looks original, but in great condition. Anyone think there are any issues?
Thanks to everyone that has replied so far.
Old May 2, 2020 | 06:37 AM
69ttop502's Avatar
69ttop502
Summit racing carries the fusible link wire.
Old May 2, 2020 | 03:04 PM
ctmccloskey's Avatar
ctmccloskey
They should never burn as they are the last protection before the battery. They should be replaced with new Fusible links. Do it right and the risk of a fire is minimized.
To 1972 Fusable Link
