Quick question throttle bracket again
Thanks Photobucket for making all the pictures useless.
He has a brand new GM cable installed, no Qjet, no stock bracket, no nothing.
New 2101 shiny intake manifold. The reflection from his overhead lights is a bit much.
I tried to fit my modified GM bracket and the POS Holley bracket to his setup, and neither one will provide a good WOT pull.
Which is strange because my GM modified bracket pulls just fine on my 2101/Holley SA 670 and GM cable. So something is different, internal cable length maybe.
I'm using the middle hole on the linkage - a straight line back to the bracket.
So he's thinking (for the price at Summit) that a CSR Adjustable Throttle Cable Brackets CSI-630C looks reasonable.
Is anyone using this and did it come with springs? Where do they mount? I can't see it in the pics online.
If you are do you have any pics?
TIA
https://www.corvettecentral.com/c3-6...et-with-353070
And the modified GM bracket I have on my Holley SA 670 looks like this.
If you look at your CC link schematic, this is a modified version of the bracket with the long mounting tab that used to go over the PB connection on a Qjet.
I really think the cable itself is maybe 3/4" longer than mine.
I think he may be right that he needs to get an adjustable bracket.
He just doesn't want to buy and install another cable or spend $100 for a Lokar setup.
The bracket I gave you below is correct for a 4150 through 1972
This is my cable, but his is exactly the same, except for the grime.
What I originally asked, before being sidetracked, is if anyone has used the CSR bracket.
I better tell my friend that this has become a 2 bottles of single malt job.
Yep save him money on bracket so he can buy good scotch for me.
