Is this normal?
Old Nov 23, 2002 | 10:52 PM
bourne62's Avatar
bourne62
Default Is this normal?
I put the front end of my '80 up on jack stands tonight to change the brake pads. While I was standing sipping my beer I noticed that the door gap at the front was three times what it usually is. The jack stands were placed approx. 3 inches in front of the door. I used my other hydralic jack to jack up the front end and was able to raise the front about four inches without affecting the jack stands at the doors. Should there be that much flex in the frame???
Old Nov 23, 2002 | 10:56 PM
Scott A's Avatar
Scott A
Default Re: Is this normal? (bourne62)
There is a pretty good amount of flex when you put it on stands. Don't forget to pop your hood, crack your doors and remove or pop your t-tops. These things have been known to crack when put on the jacks.
Old Nov 23, 2002 | 11:13 PM
'79ProwlerOrange's Avatar
'79ProwlerOrange
Default Re: Is this normal? (Scott A)
:eek: ive never heard of that, but from now on i know im gonna!! spooky.
Old Nov 23, 2002 | 11:16 PM
QuickVet's Avatar
QuickVet
Default Re: Is this normal? ('79ProwlerOrange)
never leave your car in the air longer then you need to.
Old Nov 24, 2002 | 12:54 AM
79corvette's Avatar
79corvette
I noticed the same thing on the passenger door of my 79.
Old Nov 24, 2002 | 01:36 AM
Stoge's Avatar
Stoge
I've had mine up in the air several times, and have never seen that much flex.
Old Nov 24, 2002 | 06:21 AM
Ybnormal's Avatar
Ybnormal
I have had my front end up all summer rebuilding the engine/front end and never seen that much flex. I think I would check that out real good, something doesn't sound right.
YBNormal...drive a vette
www.angelfire.com/al/swhite7/vette.html
Old Nov 24, 2002 | 07:40 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: Is this normal? (Ybnormal)
They flex, but this sounds like a lot. I've had my 69 on stands for months over the winters while working on it. I'll put jackstands as close to the "front" as possible, near where the frame turns in. In the rear, I'll place them as far "back" as possible. Chuck
Old Nov 24, 2002 | 08:03 AM
Rocket Ron's Avatar
Rocket Ron
I would check that frame out real good. Dosen't sound good to me eighter.
Also, I don't thimk it is a good idea to take away all of the upper body support by opening everything up. Then again I guess you will find out in a hurry if the frame is rotted when the t-support gives way.
Old Nov 24, 2002 | 09:27 AM
MIKER's Avatar
MIKER
My '80 has always flexed as you describe when lifted just in front of the door hinge area. I have not actually measured the difference and doubt that my door gap is THREE TIMES its at-rest width but it is noticable.
I don't like it but I don't worry about it.
I also ALWAYS loosen the T-tops and leave the doors ajar when lifting from the frame.
Old Nov 24, 2002 | 11:08 PM
bourne62's Avatar
bourne62
Default Re: Is this normal? (MIKER)
I re-checked the location of my jack stands and they were right under the door hinges. When I moved them forward to where they should be placed the flex was hardly noticable.
To Is this normal?
