Yet another A/C issue
Old May 9, 2020 | 01:39 PM
Gralls4771's Avatar
Gralls4771
Default Yet another A/C issue
I have a 79 with a completely new factory air conditioning system. It was working perfect a few days ago but today for some reason when I turn on the a/c the compressor kicks on, blows cold air but the fan speed is stuck on low. The fan speed switch functions properly on any other setting (vent, heat, etc.) This one has me really confused. Any ideas out there? The fan blower motor resister and the fan control relay are both new.
Old May 9, 2020 | 07:29 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
try the main control module, the main switch feeds the blower control then sends power to the blower resister.
the fan will run on low all the time, the low speed is fed straight form the AC fuse (on all the time), the fan switch will power the M1 & M2 speeds to the blower resister and High will be powered from the switch through the high speed blower relay.
did you change the control module in the center console?
Neal
Old May 9, 2020 | 07:37 PM
Gralls4771's Avatar
Gralls4771
Yes, heater a/c control assembly is new. I've been researching this all afternoon with no really good ideas. Absolutely every single component of the air conditioning system is new except for the fan motor (which is not original, replaced by a previous owner)
Old May 10, 2020 | 09:38 AM
chevymans 77
It can be frustrating but sometimes new parts fail, the switch needs to be removed and power checked at the back of the module/switch its self.
Neal
Old May 10, 2020 | 09:50 AM
Gralls4771's Avatar
Gralls4771
I completely agree with you, new parts do fail (or don't function at all to begin with). Its very easy to find parts for these C3's but most are aftermarket. When I replaced the heat and a/c control assembly with a new one it didn't work properly, I only got air coming out of the vents. It was a bad vacuum switch, luckily I found a NOS Delco and it worked perfect. No substitute for genuine AC Delco when you can find it. I'll continue my trouble shooting.
Old May 10, 2020 | 09:59 PM
chevymans 77
Keep at it, you'll get it sorted out, let us know what you find
Neal
Old May 14, 2020 | 03:13 PM
Gralls4771's Avatar
Gralls4771
UPDATE: Just a loose connection at the fan speed selector switch. I unplugged it, cleaned the connections and put a spot of dielectric grease on each terminal. Works perfect, strange the the fan speed worked like it should in every mode except A/C but whatever, its fixed. BTW this was the first semi warm day up here in MN to really test the performance of the air conditioning system that I rebuilt in early spring, and I have to say I didn't have hi hopes, I wasn't expecting it to work as good as a modern vehicle but I was wrong. It works great, very cold! Its going to be a good summer!
Old May 14, 2020 | 03:49 PM
L-46man's Avatar
L-46man
Gralls..you sort of beat me to it....for a short while (sorry for the pun) I couldn't get High or medium....I unplugged the fan (purple wire in my car) cleaned the ends and Bingo.....worked.
Doesn't take much resistance to f the whole thing up!
Old May 14, 2020 | 04:31 PM
Gralls4771's Avatar
Gralls4771
Im so glad it was so simple. I was kind of heart broken after spending over $1000 on all new a/c parts and several days of work replacing everything and it only worked on low. Its fixed and life is good again.
To Yet another A/C issue
