Ammeter diagnosis 1968
Old May 10, 2020 | 09:00 PM
Duffeball's Avatar
Duffeball
Default Ammeter diagnosis 1968
I need some help diagnosing my ammeter. I had one originally in the car and it would not read plus or minus when the car was on off using battery or otherwise. I pulled it out and the Gage was stiff and wouldn't allow for the needle to move. I pulled the guts out of it and replaced it with the guts of another ammeter. It allowed me to keep my good face for my 68.
I plugged everything back in and it is registering change. But it's confusing. With the car not running but in the on position I can turn on the interior lights and the blower motor and the ammeter will read in the positive 30 range. If I understand it correctly it should be reading in the negative range.
Any thoughts on what might be causing this?
Old May 10, 2020 | 09:05 PM
Big2Bird's Avatar
Big2Bird
Reverse the two leads.
Old May 10, 2020 | 10:11 PM
ddsmith60's Avatar
ddsmith60
Second Big2Bird suggestion.
Old May 10, 2020 | 10:25 PM
Duffeball's Avatar
Duffeball
Default Hmmm
I can only get it on one way due to the nipple on the lower terminal. Here's a picture of what I got. Is it possible I have the wire misplaced at a different mounting location somewhere down the line. I've heard they may end up at the horn relay.
Old May 10, 2020 | 10:28 PM
Duffeball's Avatar
Duffeball
Default Horn relay
Old May 10, 2020 | 11:19 PM
ddsmith60's Avatar
ddsmith60
The internals of the ammeter is nothing more than a coil of wire wrapped I believe 8 turns. If it is indicating backwards then that would point to the two leads being reversed. Your horn relay looks like it hasn't been messed with for a while. I sort of doubt that is the problem. The black connector at the ammeter, is it keyed or is it possible to spin it 180 degrees and plug it in that way? I really like the ammeter as opposed to a voltmeter. It lets you know quickly when things go south, before you are dead on the side of the road.
Old May 10, 2020 | 11:40 PM
Duffeball's Avatar
Duffeball
Default It's a start.
I'll try and reverse the pigtail or something. It's just that rest of AIM reads clear of wire order and felt like it did here too. But what could a swap hurt.
Side note thanks for the compliment on the horn relay. This is part of a frame off and the harness has been completely out of the car. Everything operates flawless. Key buzzer door switches the car runs like a top too. Just gotta get this figured.
Thanks for the input.
Old May 10, 2020 | 11:46 PM
ddsmith60's Avatar
ddsmith60
It is just a sensing side stream. The actual amperage doesn't go through the gage. Just an indication of the current flow in the system. You are just changing the direction of current flow (that little side stream flow) which will allow your ammeter to read correctly.
Old May 11, 2020 | 12:05 AM
7T1vette's Avatar
7T1vette
You can remove each wire and its terminal from that plastic connector by inserting a small flat-bladed screwdriver (Jeweler's screwdriver) into the entry point and depressing the retention strip on the metal terminal. Then you can just pull out the wire. Do that for both wires, reverse them and reinsert them into their new "homes". Voila' !
Old May 11, 2020 | 04:57 AM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
corroded connection on the engine compartment side of the fuse panel bulkhead connection take the bolt out and unplug it and look at the connection
Old May 11, 2020 | 07:35 AM
Duffeball's Avatar
Duffeball
Default Confirmation
Anybody have a confirmation or picture showing exactly which wires are on which pole on a 68?
Old May 11, 2020 | 08:18 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
You can reverse them on the horn relay and it may do the same thing as flipping the plug. I also tried to keep my ammeter to keep it original, but I don’t get it judged and when I got stranded because I didn’t know I lost my alternator belt I switched to a proper colored volt meter. It is a lot better trouble shooting tool and actually tells you something useful
Old May 12, 2020 | 04:46 PM
7T1vette's Avatar
7T1vette
Difficult to do with the external wiring. Both of the ammeter wires feeds into the main wiring harness bundle and are never seen again! That's because the ends of those wires connect the the primary 12vdc load wire, but at different points (about 16" apart). That length of heavy wire becomes a "current shunt" for sending a millivolt signal to the ammeter.
I tell you that so that you will not do some crazy stuff like moving wires around on the horn relay THAT SHOULD NOT BE MOVED. You can reverse those ammeter wires at the gauge; or you can reverse them at the outlet of the fuse block on the engine-side of the firewall. Once they disappear into the main wiring harness, you're done!! Use the Corvette wiring schematic to determine what color wires you need to find coming out of the backside of the fuse block and switch them there, if you have the gauge bezel already installed.
Old May 12, 2020 | 06:49 PM
ddsmith60's Avatar
ddsmith60
Internally, the ammeter wire should be wound to provide the correct indication when connected to the plug the way it is keyed. If it is backwards internally, then the easiest way to fix it is to swap the wires on the plug at the ammeter. I don't believe that the wiring diagrams are specific enough to say the black and white wire goes to a specific terminal on the ammeter. Swapping the leads at the ammeter will not cause a problem, it will just correct the incorrect indication.
Old May 12, 2020 | 08:53 PM
carriljc's Avatar
carriljc
Duffeball - Since nobody is answering you let me take a look and see if I have a picture....
Old May 12, 2020 | 09:20 PM
carriljc's Avatar
carriljc
Duffeball - I do NOT have any pictures with the leads hooked up to the gauge. If you don't have an answer by tomorrow send me a PM and I'll go open up my 68. I've done it so many times that it's easy now.
But you really should be able to swap the leads with a couple of jumpers just to test it......
Old May 13, 2020 | 12:07 AM
Duffeball's Avatar
Duffeball
Default No new info yet.
I have the leads colored and wired correctly. So no need to open it up.
Maybe I just did a bad job swapping ammeter guts
Old May 13, 2020 | 12:47 AM
carriljc's Avatar
carriljc
Ok then I won't open it up. Have you tried swapping the leads? Just to see if that's all it is? A couple of jumpers should be easy.
Old May 13, 2020 | 10:05 AM
7T1vette's Avatar
7T1vette
This is not 'brain surgery'. With engine OFF and ignition ON, turn on headlamps to create a significant 'discharge' on the ammeter. It should read on the negative side of the meter (-) to show the discharge. If it reads on the positive (+), REVERSE THE LEADS to allow it to read correctly. You either have wires reversed, the wrong ammeter for your car, or the leads reversed at the fuse block/bulkhead connector. Those are the only possibilities for a 'backwards' ammeter reading.
To Ammeter diagnosis 1968
