Does anyone rebuild the distributor shafts with the wiped out gears. I would think it would be possible to weld them up and re-cut them? anyone heard of that. Terr
If that becomes the option, that is what I will do. Just checking to see if rebuilding the shaft was possible. Still have to look closely at the housing as well. Terr
It's certainly possible -- machinists can do all sorts of things. However, given the skill and time involved, you'll pay far more than a repro, NOS, or good used. I'm saving my broken geared shaft just in case someone comes up with a $50 fix...
I just built a Tach Drive for a 63. A friend gave me a bare housing and I built it from there. I bought the parts on e-bay but they were shipped from Chicago Corvette. The shaft is readily available. About the only thing that changes from one Engine to another is the Mechanical Advance Weights and the Football on the end of the Shaft. ( It looks like a Tom Brady Football ) Replacing the Shaft is easy, but figuring out why yours failed needs to be done. Is the thrust surface scored on the housing on the Tach Drive ? What about the Bushings ? To get the correct Shaft You pretty much need to buy one from somebody who knows what he is doing.
Not gonna happen.
I have restored distributors back to the 1920's. I would rather metal spray or hard chrome a shaft with a good gear, or splice the cam onto a repop shaft.
Unobtainium parts , such as having cross dive magneto gears custom made is stupid money.
Last resort is what that is.
Its a spare distributor. I want to fix it. I like fixing things ; ) Challenges. Learn as I go. I was reading that there are basically 2 two shafts out there in the aftermarket. They are sort of a one size fits all deal. Depends on hp, I guess and they generally work well. But, GM made several different shafts with different shaped footballs. I like the idea of having the original football (as the call it) brazed on a new shaft. I will look into that and see what I find. I was also wondering what the difference is between the HD shaft and the HP shaft. Was one designed for bearings and the other for bushings?? Did they use the same football?f
Can it be done- yes. Will it be done, most likely not unless you find a retired old school machinist with a shop in his house. A job shop won't do it and if they did it would cost more then finding a couple of good used ones. I have not used a new one in about 10 years and back then the cross gears and shafts were poor, many didn't mesh correctly. More so with the cross gear then the shaft gear but I ended up using a good used one. I returned many new cross gears that were not machined correctly. Bushings can be machined and sized easy enough but the geared shafts will cost.
Any recommendations on who might have a good replacement shaft, good used one or NOS. I wonder if it is silver nickel braze. I might be able to do it by finding a used shaft. Take it to a welding shop and ask them what they think it is. Might be a fun project to report back on. But, I suspect I would have to send it off to get recurved regardless.
