Stalling When Cold. (How long to warm up?)
Old May 13, 2020 | 10:34 PM
Zellerz93's Avatar
Zellerz93
Default Stalling When Cold. (How long to warm up?)
Hi-
My car is a 1971 454 4 Speed. Square port heads and LS6 Intake. Comp Cam 11-242-3 XE268H. 160Deg Thermostat
Carb: Holley Ultra Street Avenger 770CFM Vac Secondary, Electric choke.
When I have a cold start in the morning the choke comes on, the car has the fast idle. I start driving and after a couple minutes the choke comes off. (Choke cap fully left)
At this point the RPMs drop and the car stalls whenever I try and idle. This means I must feather the throttle at red lights. If I get moving the car heats up in around 7 minutes of driving and the temperature gauge goes to around 125F or so.
At this point the car will idle at around 800-850 no problem and drive really well.
I have played with the choke and extended the time as long as possible. Still the car won't heat up before the choke/fast idle comes off.
I thought maybe it could be the thermostat either stuck open (it is only a few years old), or is 160Deg too low?
Either I need the car to run better while still cold, or find a way to get the car heat up faster.
Any ideas?
Old May 14, 2020 | 04:18 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
It does sound like the car is slow to warm up. Perhaps a new quality 180 thermostat is in order.
Old May 14, 2020 | 12:38 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Have you set the idle mixture with a vacuum gauge? I bet the screws are a little on the lean side.....
Jebby
Old May 14, 2020 | 01:11 PM
HeadsU.P.'s Avatar
HeadsU.P.
Your "warm up issue" is well below 100 degrees. A thermostat has nothing to do with it. You already said it runs fine at 125*.
We assume you have played with the idle speed set screw. We assume the timing is spot-on.
Its a modified big block and it just may never idle until it warms.
Old May 14, 2020 | 01:34 PM
Zellerz93's Avatar
Zellerz93
After reading on the forum it seems my thermostat must be reading too low. It shows 125/150 operating temperature (unless its a very hot summer day) which doesn't make sense.
It must be reading low meaning I think the thermostat could be an issue since it would delay the heating up to full operating temperature.
Idle speed I play with and it idles fine once warmed up. The idle mixture I will double check with a vac gauge.
Timing was set on the dyno.
Old May 14, 2020 | 04:46 PM
REELAV8R's Avatar
REELAV8R
I would also check to see if the accelerator pump squirt looks good and strong.
Old May 14, 2020 | 07:22 PM
HeadsU.P.'s Avatar
HeadsU.P.
I bet that if you put a 195 stat in, there would be no difference in warm up time. Then you wish it would run cooler.
Its not the stat ! Carb issues.
You also have just enough cam duration that the distributor Vac Adv is not being employed. In other words; low vacuum / little advance.
Old May 14, 2020 | 07:31 PM
Engage's Avatar
Engage
Adjust your fuel mixture.... you are running a little lean and adjust your hot idle up to 950 rpm
Old May 21, 2020 | 01:17 AM
Zellerz93's Avatar
Zellerz93
Thank you everyone for replies.
I checked the idle mixture screws and they were set correctly.
I raised the hot idle to 950RPM and the car ran fine when it was cold today.
That solved my issue - I guess my hot idle was a bit too low before.
Old May 21, 2020 | 08:20 AM
stingr69's Avatar
stingr69
Holley sells an electrodyne heat sensor that can vary the speed of the choke. You can try locating it in various locations to help the electric choke react to different engine start conditions. Worth a look.
To Stalling When Cold. (How long to warm up?)
