Door mirrors
Old May 14, 2020 | 05:11 PM
matt.sos's Avatar
matt.sos
Default Door mirrors
Hello all,
digging into my 77 a little more I’ve identified a few of the larger ticket items that are going to take a little time to work through, but the most annoying thing I have noticed while driving this is the side mirrors will not stay where I set them. The ball joint in the back of the mirror is extremely loose and anytime I get moving over 25-30 the mirrors fall down and point straight at the ground and they become basically useless. Has anyone else had this issue? Is there supposed to be a seal or anything around that ball joint? Would simply spraying some degreaser on the ball tighten it up? Any ideas?
Old May 15, 2020 | 04:10 AM
nz corvette's Avatar
nz corvette
Hi Matt,Are they sport mirrors or std?
Old May 15, 2020 | 04:30 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Aren't all 77 mirrors sport mirrors??? I thought so. Anyway. Had to replace a broken glass on the right once. Other than that. Never had a problem with mine. (77 also).
Old May 15, 2020 | 04:46 AM
nz corvette
The dual sport mirrors were an option in 77 but std mirrors were the norm...well that's my understanding,trying to tight up the sport mirrors seem almost impossible...I just bought a new one
Old May 15, 2020 | 06:13 AM
matt.sos's Avatar
matt.sos
They are standard
Old May 15, 2020 | 11:02 AM
CaptainMorganUOR's Avatar
CaptainMorganUOR
Super glue. One drop at a time, drop in and move the mirror around to work it onto the ball to build it up. That's what I did after finding the recommendation on some old threads here.
Old May 15, 2020 | 03:21 PM
matt.sos's Avatar
matt.sos
Captain Morgan,
thanks, I think I will give that a try. My only other alternative I have found is buying new mirrors.
Old May 15, 2020 | 03:32 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Originally Posted by matt.sos
Captain Morgan,
This from the NCRS forum: https://www.forums.ncrs.org/showthread.php?88889-73-Outside-Rear-View-Mirror-Repair
There's an article in the NCRS archives on tightening up the C2 mirror but the link has become 404. Not the same style of mirror but the same design.
Other folks reported success with superglue once the mirror is in position but that limits the mirror's use for anyone else.
Old May 16, 2020 | 11:55 AM
TX427C3's Avatar
TX427C3
Active Streak: 90 Days
St. Jude Donor '06-'09,'22,'25
I use a spray adhesive, and it works for quite a while. I suspect that using superglue is like my spray adhesive, it doesn't actually glue the mirror in one place, it just provides enough friction that the mirror doesn't vibrate loose.
To Door mirrors
