I hope you put the 'good' mount on the left side and the 'wonky' one on the right.....
I'm not using either one I got from Rock. The Anchor brand from the local store was better looking as far as quality, from what I can tell. They look very, very similar to the stock GM mounts I pulled from the car - except for the grease-soaked rubber with the crack separation running around the joint.
The recall someone mentioned. Was that for locking mounts?
As the story goes, customers received a letter from GM corp about bringing their newer vehicle into the dealership as soon as possible.
Also as the story goes, millions of short steel cables were attached to one side of the motor mount of millions of vehicles, "just in case" the mount let go.
Evidently, that satisfied the court system as far as a possible stuck throttle accident liability.
The cable was premade, cheap, minimal time, easy fix. But not a repair.
When I bought my '69 Camaro back in the late 70's it had a short length of common link chain attached between the drivers side exhaust manifold and the upper a-frame cross shaft. I thought "what the heck is that for"? I immediately removed it and tossed it because it made no sense to me at the time. I went for a drive and punched it.......WEEEEE!!!! Without the home made chain restraint (and obviously a broken mount) the engine torque rotated the drivers side of the engine up and the throttle linkage locked tight in the wide open throttle position. I went screaming down the road for a short while until I could shut the key off. JUST WOW!
The OP has posted a picture of the newer style safety mount that has the interlock feature so if the rubber bond shears, the metal "T" will hold it from releasing all the way. That was the final solution.
1968 or so dad let me drive the 63 Pontiac along the Salton Sea on the old two lane. He let me peg it at 120mph. It was a rolling road, so we were weightless at each crest. My 21 year old brother in back having a fit.
When we get to town, I could not slow down. I was standing on the brake with two feet, and I could not stop. Pop turned the key off, and I coasted thru the stop signs into a field.
The dam throttle linkage fell off, or the spring broke, but he understood then I was not punking him.
The good old days.
The good old days.
My big brother, who was 15, and I decided to take my uncle's '56 T-bird, which was stored in our barn, out of drive once. Hey, he told us to start it once in the while. It was going to be just one run up to the intersection, about half a mile, and back. What could go wrong. My brother cranked it up on the way back and the throttle stuck. As Bird alluded, kids don't think about shutting it off. So there I am steering from the right seat while my brother's trying to pull the gas pedal up. Fortunately he managed it, though we were passed the house by then. A quick 180 in a neighbor's driveway got us headed back home apparently without the neighbor witnessing the events.
That would have been about 1972. As Bird says, The good old days. And as Dewey Duck once said, "That's kind of fun once you know you're going to live" which we did as apparently neither our parents or uncle ever found out
From: Into the Mystic And yet, despite the look on my face, you're still talking TN
St. Jude Donor '09 thru '25
The good old days.
I'll state this but invite others to chime in if it is incorrect. I was told that if you decide to use solid mounts on the engine you need to use a solid mount on the transmission also.
That said, my original rubber mounts on my '80 have gone 40 years and 90k. I'll replace them next year when I swap out the engine. Given their longevity, I'll just replace them with rubber.
You can use solid motor mounts on a rubber trans mount but not the other way around.
Thanks for all the feedback - I'm honestly not sure what I should do. It appears clear to use a "rubber" transmission mount. What is the difference between a locking and non-locking engine mount? What was on it originally?
The locking plate rubber mounts would have been factory in '70. Think of a mount as being like an Oreo. Two metal cookies with rubber stuffing. The difference between locking and non is that in a locking mount if the stuffing separates from one of the cookies, the cookies are limited in separating from the trio. You can see the "lock" where the tabs of one cookie are captured between the bends of the other cookie. In your posted pic, you can see the two interlocking bends at the far left of the mount.
First, you want the locking type. If they do break they will still limit the travel of the engine under load but you should clearly notice something is wrong. I'm not sure what was on a '70 originally. It was in about that time frame that they had problems with the non locking type and finally went to locking to address it.
Second, on the rubber, poly, or solid, in my opinion, unless you expect some extreme use that would justify solid, I would go with rubber mounts. I look at it this way, the original rubber mounts on my '80 are are still functional. That's 40 years and 90,000 miles. Should they be replaced? Yes, and they will next year when I swap in a new engine. For basic street driving rodding, they work fine. Some will tell you that they allow vibration. Maybe so, though with everything else rattling in a vette I never noticed it. My own experience with vibration is that when you want to get rid of it, you put something that can damp out the vibration between the part that is vibrating the part that isn't. That something is usually something like rubber. In any case, if you find out you don't like them, even the good ones like those from Corvette Central only set you back a less than $100. So, you can always change them without too much loss.
Replace them. Anytime you do a major renovation you should replace the incidental parts because you can at that time.
Go polyurethane. Trust me on this.
