Holley 4011????????
Old May 20, 2020 | 09:17 AM
DaGuvner's Avatar
DaGuvner
Default Holley 4011????????
A friend gave me a Holley 4011 spread bore carb. It is a dual feed 650 cfm vac secondary with electric choke and looks to be in very good original shape. My research revealed this Holley carb was designed and approved for marine applications due to its unique bowel venting design, (prevents fumes in the bilge), and was introduced in the late 80's. It was produce for about ten years but never really caught on so it was discontinued by Holley.
It seams back in the day hot rodders on the street really liked and touted them. Are any of you guys familiar with this carb and if so what are your opinions of it for street use. I'm running a quadrajet that Lars helped me get dialed in along with proper timing setting on my 420 HP 383 stroker.
I am curious about this carb and am thinking about trying it out for fun. I have disassembled, cleaned and have a rebuild kit on order for it. (yes kits are available)
Here's the link to the kit I have ordered: https://allcarbs.com/product/holley-...ry-model-4011/
Here's a picture link to a carb identical to mine only it has a manual choke: https://www.ebay.com/itm/Holley-List...gAAOSwGENevwY7
Old May 20, 2020 | 09:40 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I ran that exact carb for several years until I stepped up to Holley Street HP. I never had any issues with it except it was vacuum secondaries and I wanted mech'l in my old age.
Old May 20, 2020 | 09:56 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
They work fine but I doubt you will gain anything.......Summit bought the tooling and sells the Square bore ones now. The only rub about these is that you have to physically remove the carb from the engine to change a power valve.
I ran a square bore when they first came out in 1991 on a 350 in an S-10 that I built as a young man......it worked very well. Wanted to be able to jet without spilling gas everywhere.
Jebby
Old May 20, 2020 | 11:14 AM
derekderek's Avatar
derekderek
That is the real advantage in a boat. There is no float bowl gasket that could leak. Get a little gas drip in your car the wind is blowing through your engine compartment and evaporates it out. Get a gas leak in your boat there is no wind. fuel vapors can quickly get to explosive levels. functionally they are the same as any other Holley. which is not a bad thing.
Old May 20, 2020 | 12:52 PM
MelWff's Avatar
MelWff
You already have a Lar's setup Quad which has to be better than the 4011.
To Holley 4011????????
