coolant temperature sensor
Old May 26, 2020 | 01:30 PM
nearflack's Avatar
nearflack
Default coolant temperature sensor
Only posts I see are very old so posting again for information.
I have a 1980 L-48. I think the current sensor is bad as the gauge tests good. The current sensor has a "button" connector and all I find as a replacement have the blade connector. The sensor wire appears to be factory and has the button connector on it. The only sensors I find with button connector are for older model C3s. Do I use an older sensor or get the one with the blade and change the end on my wire.
Old May 26, 2020 | 02:30 PM
Bikespace's Avatar
Bikespace
My L48 80 has a spade connector on that sender. But so do the "correct" sending units at Zip:
https://www.zip-corvette.com/79-80-t...ding-unit.html
Interestingly, taking the GM Part number, 8993372, and entering it at RockAuto, shows senders with spade connectors as well.
The "correct" harness also expects a blade-type connection.
https://www.zip-corvette.com/77l-82-...ss-repair.html
Is it possible your engine/heads are not original? Or perhaps just your sender?
Old May 26, 2020 | 02:47 PM
jeffwebley's Avatar
jeffwebley
I'm not 100% certain, but I believe the connector body on your harness will work with both button and spade terminals.
Worth a look see.
​​see.
Jeff
Old May 26, 2020 | 02:52 PM
Sayfoo's Avatar
Sayfoo
FYI
I just went through this on my '69.
The plastic protector on my wire clip had disintegrated so I bought a new pig tail also. Before changing the sensor, I tried grounding the wire clip and nothing happened (should have done this before buying a new sensor). So I spliced in the pig tail first and the gauge worked. Somewhere in the 1ft of open wire from the harness to the sensor the wire had failed. It looked fine on the outside.
Anyway, check your wire first.
Old May 26, 2020 | 03:33 PM
nearflack's Avatar
nearflack
Originally Posted by Sayfoo
FYI
Thanks, wire and gauge is good. Needle pegs when wire is grounded. Guess I’ll just change the plug. I ordered new sensor from Zip Corvettr
Old May 27, 2020 | 04:48 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Call Willcox first. I needed a smaller NPT thread on my 68 for an aluminum head I didnt want to drill and tap. The labor is fair if you need something like that done, but you should call and see if he has exactly what you want in stock.
To coolant temperature sensor
