Rear brakes retainer 'u'-clips
Old May 28, 2020 | 12:01 PM
Novusuhu's Avatar
Novusuhu
Default Rear brakes retainer 'u'-clips
Hey everyone
I’m working on my brakes for about a month now and it’s hell!
I will have to replace the rear retainer ‘u’ clips for the rear brake hoses. (rear hoses and lines also, but that won't be a problem)
They are so ‘rotten by rust’ they fell apart when I removed them.
I’m from Belgium, so won’t (can’t) buy from US corvette vendors because of the very high shipping and import costs. There one vendor in the Netherlands, but he asks €6/u-clip (excl. Shipping and TAX). This I find too much for such small parts.
Do u-clips from ‘Dorman’ (or maybe other cheaper brands) fit the corvette brake lines?
I don’t know what specifications/dimensions (of the retainer) are important for this part.
Old May 28, 2020 | 01:50 PM
mikep3's Avatar
mikep3
Are you referring this $0.51 US dollars?
https://www.rockauto.com/en/catalog/...ose+clip,12216
Old May 28, 2020 | 02:19 PM
Novusuhu's Avatar
Novusuhu
Yes.
Old May 28, 2020 | 07:09 PM
mikep3's Avatar
mikep3
So if I put 8 in a mail envelope and sent them to your home, then the Import Tax People in the Netherlands would be very unhappy!
Old May 28, 2020 | 07:25 PM
mikep3's Avatar
mikep3
Well I checked UPS and FedEx and they want $100 plus USD for shipping. I'll check US Mail in the morning.
Old May 29, 2020 | 10:50 AM
C3TPI's Avatar
C3TPI
I used the Dorman clips and they work fine. These things are pretty standard. Got mine off of Amazon.
Old May 29, 2020 | 11:50 AM
7T1vette's Avatar
7T1vette
Surely, there are similar type clips in Europe that could be modified to fit. Hardened steel U-clips or properly sized C-clips would to the job. There is not much stress on those clips...but they MUST be reliable, so hardened steel is a must.
Measure the opening required to slide over that groove diameter in the fitting, as well as the groove width. Take that info to some general fastener supplier and ask them what might be used for your application. It's worth a try, rather than be 'suckered' for $100 in shipping fees for a $3 group of parts.
Old May 29, 2020 | 04:22 PM
Peterbuilt's Avatar
Peterbuilt
Default Mickey Mouse Clips will work!
Maybe you can find something like this in Belgium.
Old May 29, 2020 | 08:44 PM
revitup's Avatar
revitup
I would be very hesitant to substitute a different 'similar' part for this retainer. Brake line retention is a safety issue and failure could be a critical issue.
Old May 30, 2020 | 06:45 PM
kodpkd's Avatar
kodpkd
How much does it cost to send a small box from the US to you?
Old May 30, 2020 | 07:20 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
rough USPS calculation to Belgium for padded 9x12 envelope is $37.50
You can probably send for less in a small padded envelope at the counter.
Old May 30, 2020 | 09:01 PM
60 SHARK's Avatar
60 SHARK
For that application, in a pinch when I couldn't get parts on time, I have used annealed tie wire, or called bailing wire, and also used stainless steel safety wire, to hold the brake line and hose in place,,It can be done safely ,,, IMHO ZIP tie should work also,,,
Old May 31, 2020 | 02:29 PM
Novusuhu's Avatar
Novusuhu
I asked a local 'American car and truck garage' about the clips... They said: We don't have it in stock, but we can order (will take min. 2-3 weeks)...
I found these two options lately, but I'm not sure they'll fit:
$18 for a pack of 5 incl. shipping) reviews say they fit an '81 Transam. Will they fit a C3?
https://www.amazon.com/Gold-Cadmium-Flex-Hose-Retaining/dp/B01MYZ0SCR/ref=sr_1_22?dchild=1&keywords=flex+hose+retaining+clip&qid=1590685122&sr=8-22 https://www.amazon.com/Gold-Cadmium-Flex-Hose-Retaining/dp/B01MYZ0SCR/ref=sr_1_22?dchild=1&keywords=flex+hose+retaining+clip&qid=1590685122&sr=8-22
Chevrolet truck parts shop (Netherlands) 'brake hose clip 1941-1974 for flex brake hose. It fits Chevy trucks...
https://www.prinstruckshop.nl/a-4551...4/#description
Old May 31, 2020 | 02:41 PM
Peterbuilt's Avatar
Peterbuilt
The first link lists the sizes, do you have an old clip to measure against?
Old May 31, 2020 | 02:49 PM
60 SHARK's Avatar
60 SHARK
I think he said the old ones were beyond salvaging,, if a specific size is needed, just put your micrometer on the brake hose fixture that receives the clip, to get exact size,,,,
these two listings posted should do the trick
Old May 31, 2020 | 05:24 PM
barkingrats
Amazon listing by Inline Tube which makes a bunch of repro steel brake, trans, etc. lines:
https://www.amazon.com/64-79-Rubber-Retainer-Bracket-D-8-11 https://www.amazon.com/64-79-Rubber-Retainer-Bracket-D-8-11
1955-87 GM Brake Hose Clips 4 piece set These clips are used on countless GM Cars in the 50's,60's, 70's & 80's to hold the flexible brake hose into the frame bracket. There are usually 2 at each front wheel and one for the rear drop hose. But in some cases 4 are used on a corvette. These are the factory correct black finish clips with the full length tab.(the ones with the short tab that does not run the full length of the clip is aftermarket or a cheap replacement as are the gold and silver clips) This is an exact Inline Tube reproduction, Correct Size, Shape & Finish.
Q&A at the bottom says gap is 1/2" ---- I just measured a couple off of my '72 and they're also 1/2" gap.
Old May 31, 2020 | 05:45 PM
C3TPI's Avatar
C3TPI
Those ones from Amazon should work, they're pretty standard like I said.
Old Jun 1, 2020 | 06:41 PM
Novusuhu's Avatar
Novusuhu
I asked the 'Chevrolet truck parts shop (Netherlands)' to measure the inside width of the u-clips they have.
They ask €1,25/clip, which I find a reasonable price.
The shop will send me an email with the info.
I will send an extra reply, so other guys from around here can find such clips.
To Rear brakes retainer 'u'-clips
