Adding larger sway bar radiator clearance 79
My template to cut
New 6 inch bolt with 1 5/8 spacer paragon
Original assumed replaced at one time longer bolt with 2 inch spacer..not so snug
Couple of questions I’m installing a 1 1/8 new gymkhanaquasi clone bar to the front of my 79 7/8 current bar I’m about a papers width from the dewitts aluminum radiator now and I assume with the larger sway bar I will be hitting or touching it my question is number one can I use the lawnmower blade that’s about 7/16 inch thick and cut a template and put a spacer on the bar to get it further away from the radiator and will that be OK with the geometry?
and a question to the current swaybar links that are on there I think Have been replaced with generic longer bolts that stop when the threads ending and with a 2 inch spacer. I bought some poly paragon correct ones that have 6 inch bolts in a 1 5/8 spacer. is the 15/8 spacer the correct ones? I am assuming it’ll fit better because right now it’s kind of leaning like it’s off angle thank you
now still waiting for my poly bushings to instal!! 3 weeks backordered....
kinda fun whipping the rear end around with rear bar on and 7/8 front..wonder what poly and 1 1/8 brings
I didn't clean up anything for the picture because I broke the nose out racing and was doing body work.
The blocks are forward of the center of balance. I got it to @ 42% front and 58% on the rear tires. The side to side on four corner scales was pretty even jacking the springs
I suppose I’ll try it without the spacers first if my bushing ever comes but I have the blocks made as a back up and to provide clearance
