Alarm switch?
Old May 29, 2020 | 01:07 PM
SouthStar's Avatar
SouthStar
Default Alarm switch?
I've got a 1969 Corvette convertible which had the factory alarm option. I've got a switch in the rear and a switch in the driver's gill area. From research the switch in the rear is right. Later years had the driver fender switch. The car came with keys that work the rear switch. The alarm currently doesn't work. The fender switch doesn't except any key I have. Rear key, ignition, or door. The fender switch is very hard to get to for me to tracy the wires. Any ideas?
Rear
Old May 29, 2020 | 01:14 PM
MelWff's Avatar
MelWff
I also have a 69 since 73. The rear switch is factory the fender is not . You will have to trace the wiring for the fender switch. The factory alarm is a horn located on the drivers side rear behind the wheel. I believe the horn relay is located in the far right storage compartment where the jack is stored.
The ignition and door should use the same square head key. The oval key is for the storage compartment and the spare tire lock. The round key is for the factory alarm.
Old May 29, 2020 | 01:28 PM
KenSny's Avatar
KenSny
Is it possible the side grilles were replaced at some time, accident maybe, with a later year?
Old May 29, 2020 | 01:35 PM
SouthStar's Avatar
SouthStar
I thought about a replaced fender too. 68 and 69 are the only two years with shark gills and to my knowledge both years had the alarm switch in the rear. Also looking the car over I don't see any signs of damage or replacement
Old May 29, 2020 | 03:00 PM
MelWff's Avatar
MelWff
The car had the optional louver trim at some point. You can see the well nuts.
Old May 29, 2020 | 04:12 PM
SouthStar's Avatar
SouthStar
I took them off to painting the back area black. That's why I'm dealing with the switch. I'd like to remove the switch if it's useless.
Old May 29, 2020 | 04:27 PM
Peterbuilt's Avatar
Peterbuilt
You have to get under there and
#1 see if any wires are connected
#1a identify the colors
#2 the switch is held by a clip or a nut, easy to remove.
Enjoy your project.
Old May 29, 2020 | 06:27 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
It's a nice looking installation and would have been a better placement than the center of the rear panel, in my opinion.
Old May 29, 2020 | 06:56 PM
SouthStar's Avatar
SouthStar
Tried to get to the switch from the engine compartment. Its behind a fiberglass wall. Tried from inside the car behind the speaker. No luck. Didn't want to put it on the lift to try from underneath. Just painted it. Looks some much better.
Old May 29, 2020 | 07:01 PM
MelWff's Avatar
MelWff
You removed the driver's side speaker/kick panel?
Old May 29, 2020 | 07:18 PM
SouthStar's Avatar
SouthStar
Yes. I remove the speaker panel and speaker. Also look up around the fuse box area. I believe it's outside of the interior area. Right behind the fuse box. If I get under the car and remove the skid plate and reach above the frame I might be able to get to it. That's another day project.
Old May 29, 2020 | 07:57 PM
Peterbuilt's Avatar
Peterbuilt
It could be for the alarm or a 'kill switch' or nothing.
Once you check for wires you'll know better.
Old May 29, 2020 | 08:32 PM
OLE442's Avatar
OLE442
From: Way too effing close to the city.......NRA Life Member!
Aftermarket security system switch?
Old May 29, 2020 | 09:27 PM
kansas123's Avatar
kansas123
Could a locksmith make a key for it with it where it is? Probably not? If they could, at least you could turn the lock and see what happens. I'd be just to darn curious and impatient.
Old May 30, 2020 | 05:45 AM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
That's not an original Briggs & Stratton alarm switch in the rear panel
Old May 30, 2020 | 06:42 AM
ralphspears
Banned Scam/Spammer
This switch was used 1968 69 and early 1970
Old May 31, 2020 | 12:28 AM
SouthStar's Avatar
SouthStar
I've found 50 years of meddling. I figured the rear switch was wrong. I still need advice on how to get to the unknown switch. I can reach all riders gills from the engine bay. The rear drivers gill seems to be in a cavity between the engine bay and cabin. Hopefully someone has replaced a driver's side front finder and knows the construction of that area. Thanks for the help.
To Alarm switch?
Old May 31, 2020 | 06:21 AM
ralphspears
Banned Scam/Spammer
Remove the left kick panel where the radio speaker is and you can remove the vent door and reach in there. You remove the vent door it has a spring on one of the pivot shafts you either lift it up or down to get it out then you can reach inside
Old May 31, 2020 | 08:54 AM
ralphspears
Banned Scam/Spammer
Old May 31, 2020 | 10:40 PM
SouthStar's Avatar
SouthStar
Thank you. Will try that.
