Drive Shaft
Old Jun 4, 2020 | 11:02 PM
Giddy-up Go's Avatar
Giddy-up Go
So at this point it doesn't matter which end is which when I hook up my driveshaft
Old Jun 5, 2020 | 09:35 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
If you don’t know which end was balanced to which yoke, no. If you drive it and get a vibration, either flip it or take the tranny slip yoke and get the assembly balanced. Shortening and balancing was $85 around here. Just balancing shouldn’t be tooo expensive...
If yours had all the rust damage, definitely not going to matter and will need balancing any way
Old Jun 5, 2020 | 09:49 AM
Rescue Rogers
Originally Posted by kodpkd
Is that an original bump or something that somebody added?
Compared 2 shafts. It was added
Old Jun 5, 2020 | 09:50 AM
kodpkd's Avatar
kodpkd
When the vet was build,,, how was the drive shaft balanced? I have heard a few different opinions. Obviously it's best to mark it and reinstall it just like it came out, but what is really necessary to keep track of?
Old Jun 5, 2020 | 09:56 AM
Rescue Rogers
Exactly how it came out, (which end went to the tranny slip yoke and which way it was oriented......rotated and mounted). But at this point, 50 years later, is it going to be the same as it left the factory and does it have the original u joint it started with and was balanced to?
