master cylinder bench bleeding
Old Jun 8, 2020 | 08:15 AM
3X2's Avatar
3X2
Default master cylinder bench bleeding
After 50+ years on the car, the master cylinder started leaking. I bought one of the GM restoration master cylinders and now it is time to bench bleed. At what point during the bench bleed do I bleed through the bleeder fittings? Before or after bleeding through the brake line fittings? Caveat: some threads I read said that the bleeders do not need to be bled since they were used to bleed the system when the car was built.
Old Jun 8, 2020 | 08:50 AM
HeadsU.P.'s Avatar
HeadsU.P.
That's the story I have heard also. Production-Line Bleeders.
However, one would think that if you do not open it just a pinch & bleed, there has to be a bubble there at the port.
I have never owned a MC w/bleeders. But in a logical sense, I would at least shoot some juice through both bleeders once.
Old Jun 8, 2020 | 09:15 PM
7T1vette's Avatar
7T1vette
Couldn't hurt to finish the M/C bench bleeding by cracking each bleeder and then closing it during a single cycling of the M/C. That way there is no chance of 'sucking' in any air via that bleeder.
Old Jun 8, 2020 | 09:32 PM
3X2's Avatar
3X2
Here's what years of neglect results in. I'll assume a non sealing lid gasket. The two lines out of the master were clear of this sludge
Old Jun 8, 2020 | 09:50 PM
HeadsU.P.'s Avatar
HeadsU.P.
Wow! That's all. Just wow.
So. How was the car fished out of the bottom of the lake?
Old Jun 9, 2020 | 06:43 AM
3X2's Avatar
3X2
That is what years and years and years of sitting and not changing brake fluid will do.
Old Jun 9, 2020 | 08:52 AM
78pacer's Avatar
78pacer
Disgusting...
Old Jun 9, 2020 | 09:06 AM
Big2Bird's Avatar
Big2Bird
Yet it worked fine for 50 years. I bet I have some arteries that look like that.
To master cylinder bench bleeding
