Hi Perf motor and transmission upgrade 64 coup
I know this tread is for the C3 but the C2 is basically the same.
I recently purchased the car with a mid 80,s low HP 350 and TH350 transmission and i am going to change both at the same time, the car has a fresh 3:36 posi installed, car was originally a 4 speed but that was pulled years ago.
I will be primarily just street crusing and not driving long distances often, i have newer cars for that, but thought the OD my be better for resale
I have narrowed down the motor upgrade the the Blue Print BP3961CTC motor.
Now for the transmission do I go the easy route and buy a built TH350 with 2200 stall for under $1800 or take this opportunity to go with an OD transmission?
I have looked into TCI, Monster, Bowe Tie, and Silver sport, prices range from $2700 to $4100.
they all recomend a different transmission. and parts to complete the install 700R4, 2004r, 4L65E??
The 700r4 is the most popular it seems but it has the biggest ratio gap from 1st to 2cnd.
If anyone has first hand experiance I would appreciate your advice.
Dr. Detroit
Received 3,897 Likes
If you have the money......buy the OD trans, the difference is staggering to say the least......do not worry about the 1-2 gear drop, it is wide but millions have used them.
After you sort the driveshaft and linkage...MAKE SURE you buy the proper TV cable bracket and cable itself. The TV cable on these is the pressure control for the valve body and the lifeline of the trans. It also has to be adjusted proper. There are many good instructions and diagrams for this on the net......
http://www.cpttransmission.com/tech_tvcable.htm
https://static.summitracing.com/glob...structions.pdf
Jebby
Jebby
storch (06-10-2020)
427 ... NEW block, more grunt, Lots more potential ... comparing same "dress" levels, about $2300 more
https://blueprintengines.com/product...block-ps4272ct
yes that is another step up but for a street weekend cruser I think the 396ci is pushing the HP limit already, i found the motor shopping is straight forward compared to the transmission options
The smarter move was going to a tko600 with a 4.11 rear end .64 OD. With a 3.36 I would install the .82 OD Or even feasibly the tko500 with the lower first gear.
storch (06-10-2020)
The man Art Carr sold his biz many years ago and went broke and restarted again. So it's possible to get the power rating he claims. You might just need to add it up. tranny plus TC..... cooler.... I came to the conclusion that manuals last a long time and they are fun
Received 3,043 Likes
St. Jude Donor '05
like the gearspread of the 200r. Wtih big torque youll be smiling
I would tend to say that you would not want the 400 hp model and you would need the upgraded 600 + HP unit. With some quality 9.5 inch efficient 3500 stall with you motors tq rating. Many years ago I bought a B&M Street fighter or Saturday Night special 3000 stall and car always was doing 3000 rpm because of slip unless you went faster. So it was just creating heat an wasting hp and fuel. An efficient TC even my 3800 stall would only change a couple of hundred rpm cruising down the freeway at 80 mph when I would flip the manual lockup toggle switch
http://www.cpttransmission.com/2004R_trans_400hp.htm
