Vintage air condenser installation?
Old Jun 12, 2020 | 07:34 PM
Bhebert449's Avatar
Bhebert449
Default Vintage air condenser installation?
Installing the condenser on my 69 non air coupe and the instructions show OEM mounting holes at the bottom of the core support. My car does not have bolts at the bottom of the core support. Has anyone run into this issue? Will I need to drill holes in the core support?
Old Jun 12, 2020 | 08:39 PM
MelWff's Avatar
MelWff
In your second picture what is that piece that looks like a clip with a hole in it towards the top of the picture?
Old Jun 12, 2020 | 11:15 PM
vettebuyer6369's Avatar
vettebuyer6369
Consider using different thread titles as you could get one removed as a dupe.
Old Jun 13, 2020 | 01:00 AM
Busrydr's Avatar
Busrydr
Bhebert449,
I installed those brackets in a 73. There were pre-existing holes in the radiator support. Those same holes would have been used for the OEM condenser brackets. My car was non-A/C originally but still had the holes already there.
Old Jun 13, 2020 | 01:38 AM
Bhebert449's Avatar
Bhebert449
Originally Posted by Busrydr
Bhebert449,
well I ended up having to remove the radiator to mount screws in the bottom support.
Old Jun 13, 2020 | 02:19 AM
Busrydr's Avatar
Busrydr
When I tooka look, I saw there would be no way around pulling the support if you wanted done right. Good luck with the rest of the install.
Old Jun 13, 2020 | 11:16 AM
Corvettedave02's Avatar
Corvettedave02
C3. 427, 4-link, c7 z06
I just installed my VA condenser last week and didn’t see any holes but my core support was modified/reinforced awhile back. I bent the bottom brackets up and drilled a hole to put a quarter inch bolt through the core support to keep it secure. I don’t see how it could be a ptoblem. The top bolts matched up perfectly.
To Vintage air condenser installation?
