Headlight switch issues
Old Jun 13, 2020 | 12:01 PM
seafox210's Avatar
seafox210
Default Headlight switch issues
While I suspect replacing the HL control in my 79 will solve these issues:
1. Headlights on and rotation of dimmer causes drastic tach variations.
2. Headlights on causes issues with instrument lights.
3. Headlights on causes reverse function of high beam/low beams.
4. Headlights on causes turn signal indicators to "stick" on given dimmer rotation position.
Everything works fine when HLs are off. Day car only? LOL! My wife and I occasionally like to enjoy an evening dinner date in the ole Vette.
Thanks all!
Old Jun 13, 2020 | 12:05 PM
Big2Bird's Avatar
Big2Bird
I do not think it's the switch. Gremlins are usually caused by faulty grounds.
Old Jun 14, 2020 | 09:42 AM
henrikse's Avatar
henrikse
I agree. If there is grounding issue power looks for another way to ground and will find a path causing gremlins
Old Jun 14, 2020 | 12:37 PM
seafox210's Avatar
seafox210
What would be the ground, though? There seems to be a lot tied into this "gremlin" Thanks all.
Old Jun 14, 2020 | 02:38 PM
7T1vette's Avatar
7T1vette
The grounding in question is likely in one of two (or in both) places:
1. The main headlamp ground wire/terminal on the framework behind the headlamp buckets (left of center)
2. Omitted, damaged, or poor contact on the headlamp switch grounding strip (metal strip mounting under the switch mount and running to ground point on inside of driver's dash pad).
Check images/drawings in the electrical section of your A.I.M. for detail.
If you correct the grounding problems and the headlamps still work "backwards", the wiring on the headlamp 'brights' switch (floor mounted) is not connected correctly....OR... the sockets on the HI and LO beam lamps are reversed. Again, check AIM for correct orientation.
Old Jun 14, 2020 | 02:55 PM
henrikse's Avatar
henrikse
I would get a wire from negative battery and touch it to the ground on headlight switch or ground at lights to test. Battery ground is where grounds all end up . Getting at back of headlight switch is no easy task but if you read up it is doable without taking dash out. These headlight switches are terrible and even new ones are hit and miss. Probably where your trouble is
Old Jun 14, 2020 | 03:20 PM
Big2Bird's Avatar
Big2Bird
You buy the GM switch for the Camaro and swap the vacuum parts.
Old Jun 14, 2020 | 04:08 PM
seafox210's Avatar
seafox210
Thanks, will give it a shot.
Old Jun 14, 2020 | 04:11 PM
seafox210's Avatar
seafox210
Thanks, will give this a shot.
To Headlight switch issues
