Vintage air compressor belt
Old Jun 13, 2020 | 06:31 PM
Bhebert449's Avatar
Bhebert449
Default Vintage air compressor belt
Finally have the compressor installed on my 69 non air coupe. It went well and appears to line up according to the instructions.
I need to purchase a belt. The instructions recommend 47-48” Dayco Gates or Goodyear V belt. I measured with a piece of string and measured around 46”.
is there a specific width or are they all pretty much standard. Also will I have to remove the fan to get the belt on the water pump? Any recommendations?
Old Jun 13, 2020 | 08:37 PM
HogSlayer's Avatar
HogSlayer
3rd Gear
On my 71 big block the Gates belt number is 11A1170. I have electric fans so Im not sure about how you go about the installation
Old Jun 13, 2020 | 10:12 PM
Bhebert449's Avatar
Bhebert449
Went with the Gates 7480. It’s 48 - 5/8” long. Just right for hood clearance!
Old Jun 13, 2020 | 10:16 PM
Big2Bird's Avatar
Big2Bird
You ideally want the top of the belt flush or slightly above the sheeve. Not too high/ thick.
The belt sides have the most purchase, and slip less.
Old Jun 13, 2020 | 10:19 PM
7T1vette's Avatar
7T1vette
Well, there's some info you need to know, first. These V-belts come in many configurations. There are differently angled V's; and there ARE different widths. Some are English and some are metric.
If you look at the (2) belts on your water pump, you will notice that the belt on the front pulley completely fills the V...the outer surface of the belt is approximately at the O.D. of the pulley V. But, the rear pulley has a belt that is down deep in the V. The front belt is of the correct width; the rear is too narrow for the pulley. The belt needs to be at the O.D. of the pulley to assure that the inner surface of the belt does NOT get down near the bottom of the groove. Otherwise, it can slip and squeal and it will NOT be able to handle the power it needs to do its job correctly.
The A/C compressor you purchased should have specifications for the design of its drive pulley. The engine mounted pulley needs to be of that same configuration so the belt you choose will work properly for both pulleys. For sizing, you need to measure distance around the outside surfaces of both of those pulleys, and then subtract about 1/2 inch to 1 inch, depending on how long the belt needs to be. These belts should be somewhat stretched when properly under tension, and after a week or two of use, a new belt needs to be re-tightened as it will permanently stretch a bit during that early usage. I suggest that you position the compressor near the tightest side of its adjustment, as you will need to extend that adjustment soon after installation and you don't want to run out of room.
Good luck.
P.S. The 'width' measurement of the belt needs to be about the same as the width of the pulley groove to which it is mated, at the outer diameter of the pulley.
Old Jun 13, 2020 | 10:22 PM
Big2Bird's Avatar
Big2Bird
What he said.
Old Jun 13, 2020 | 10:36 PM
interpon's Avatar
interpon
And buy larger and smaller by 1/2 inch so as to not run back to store 3x
thats a great looking compressor
Old Jun 14, 2020 | 10:25 AM
Bhebert449's Avatar
Bhebert449
Here is a pic of the belt installed.
Old Jun 14, 2020 | 10:59 AM
backyardsinger's Avatar
backyardsinger
Looks great I got mine done and charged up last week and drove it everyday I really like having the ac working did not effect my idle or tempeture even sitting in traffic and 93 degrees outside but I can not wait for rainy season to end so I can pull the tops off
Old Jun 14, 2020 | 02:25 PM
7T1vette's Avatar
7T1vette
Looks good. That inner belt on the water pump-to-crank is not exactly correct. But, if it is not squealing, leave it alone. That belt is the "safety valve" for keeping water flowing thru the engine, should the other belt[s] fail. It will get you home with the engine still running, in a pinch.
Old Jun 14, 2020 | 02:31 PM
Bhebert449's Avatar
Bhebert449
Originally Posted by 7T1vette
Looks good. That inner belt on the water pump-to-crank is not exactly correct. But, if it is not squealing, leave it alone. That belt is the "safety valve" for keeping water flowing thru the engine, should the other belt fail. It will get you home with the engine still running, in a pinch.
yeah I can tell it’s too narrow but would be pain to change.
Old Jun 14, 2020 | 10:41 PM
ddsmith60's Avatar
ddsmith60
I don't know if I can agree on the water pump to crank belt discussion. GM 3952336 is what is called out in the assembly manual and it sits down in the groove. It is not flush with the top of the pulley.
Old Jun 15, 2020 | 06:47 AM
frankcfalco's Avatar
frankcfalco
2022 Corvette of the Year Finalist -- Modified
I have the Vintage Air on my 1969 427 and I use the Gates Belt 7570. Outside Circumference is 57 inches. Clogged belt and works great
To Vintage air compressor belt
