79 corvette high alternator output
your voltage looks good to me.
my 77 sits right up at the "Red line" of the volt gauge as well. Untill my fans kick on.
Sounds perfectly normal for a high output alternator.
Drive it, mine is running 14.5 now....
60
Running voltage that high (when not required) will shorten the life of your battery significantly.
Don't believe it? That would be YOUR problem.
The alternator in a C3 has NO circuitry that determines how charged the battery is which means it has NO mechanism to lower the voltage as the battery reaches full charge. The regulators that came in a C3 10SI have a stupidly simple circuit. Some resistors, transistors and a zener diode or two are about all that's in there. Just a stupidly simple analog regulator that varies the field current to maintain a constant output voltage. It certainly does not contain anything that regulates voltage based on battery charge.
The sensing wire also doesn't get anywhere close to connecting to the battery on a C3, It splices to the charging wire in the harness just downstream from the alternator.
You are confusing the basic 10SI with the newer alternators that have the onboard electronics actually dictating what the output should be. The electronics monitor the battery load and determine a state of charge and will cut-back the alternator output when possible mostly to save a little fuel.
So, if the alternator is setup to regulate at 14,7V then it is always going to output that voltage. If the battery is in jeopardy then some intervention needs to be done to fix the voltage because the alternator won't just magically lower it's output to save the battery.
Overall, good job with the attitude for someone who doesn't know what they are talking about.
Take a jumper and connect from the output stud to the red wire at the connector and see what happens. If the alternator lowers its output then you need to investigate the red wire further. If not, then it's just the way it is. The charging voltage has crept up over the years as battery technology improves.
Regulator 13.8 to 14.8 volts at 85 degrees.
https://www.gmheritagecenter.com/doc...t-Corvette.pdf
The voltage found in the main power wire (electrical harness) is used by the alternator to REGULATE its output voltage. The lower the voltage it detects, the higher the output voltage. If that were not the case, alternators wouldn't have REGULATORS built into them.
So, If your battery is fully changed and the alternator is sending 14.5-15.0 volts to it all the time, your battery will boil over and be "toast" in short order.
