Hi all - planning to reinstall my rebuilt motor and tranny this weekend. What do you all suggest for manual transmission fluid? I want to put "good stuff" in it.
Depends on the trans. Some manuals with bronze blocker rings (syncro's) don't shift as well with synthetics as they do with petroleum based lubes. GL5 can cause corrosion of bronze blocker rings. So for an older trans like the Borg Warner T10 or Muncie, I'd go with GL4; you can't go wrong. But GL4 is getting hard to find. If you want the best in my opinion, go with Red Line MTL GL-4 full synthetic. That's what I'll be using in my ZF six speed. I have been using Red Line lubes in my Harleys for 25 years and they perform exceptionally well in the straight cut gear boxes. You can get it on Amazon.
If you have a Muncie, use Sta-Lube GL4 (85W90). The "good stuff" isn't necessarily the best for 50+ year old transmissions. I've used it for years. Most old school Chevy guys use it. I recommend staying away from synthetics (too thin & slippery) & GL5 (corrosive to bronze).
I race my car and have found that the non synthetic oils work a little better. I have used Brad Penn in the past and now use Driven oil. These are GL-4 oils and are available from several on-line sources.
Thanks for the input! This is a "new old" transmission. It's the original 50 year old transmission (4-speed), but was just rebuilt, including replacing gears 2 and 3. Looks like the GL-4 is the thing...does brand matter much? What does anyone think of Royal Purple? I believe it's full synthetic tho...
Royal Canadian Navy
I switched from gl5 redline synthetic to lucas 85-140 non-synthetic. It does shift a bit better. Btw, redline gl5 syntetic won't damage bronze. It's stated on their website.
Thanks - stay healthy!
Sta-lube 85w90 is what I run. It was recommended by Jody of Jody’s transmissions.
By "50+ year old" I meant the design. Mine was totally rebuilt too. Guy that rebuilt it (30+ years of rebuilding them) told me Muncies shift better, wear better, and are quieter with non-synthetic oil.
Gotcha - thanks for the input. Sounds like the Sta-lube 85W90 is the way to go!
GL-4 conventional gear oil in an old gearbox. Brand is not as important.
Some well respected guys do recommend synthetic but I have had issues with seal leakage, shift feel and noise with synthetic lube so the cheaper old school conventional gear lube fixed those issues.
Metal-to-metal wear rates with full synthetic products is SOOOO much lower than with organic products, switching is a no-brainer. Thinking that 'old' mechanical parts can't benefit from full synthetics is just like thinking that EFI can't work on an old engine.
You just need to find out which synthetic is the best for your particular transmission.
Corrrecto Mundo Again, resdoggie.
In fact, most GL5's specifically note, the wive's tale, that modern GL5's will degrade bronze synchros....they will not. Also, My 78 Super T-10 specifically notes GL5 in the owner's manual and backward compatible to GL4 which indicates more about the bronze erosion issue which probs came about early on with the introduction of GL5 fluid but was quickly corrected and the myth lives on with modern fluids.
As noted above, another wife's tale that conventional oil is better for old school tranny's..not a chance. A super synthetic lubrincant has no idea whether the gears and seals are old or new......
