Replace lip seals with O ring kit...
Thanks....
Rear caliper bore is 1 3/8" (1.375) {34.9mm}
To change from lip seals to 'O' rings you need a new piston.
Using the spring or not is up for debate.
Change the rubber lines.
Check that the hard lines will unscrew.
Check that the bleeders open.
New pads.
Check the rotor run out.
Was really hoping to hear from Muskegon, to insure they used stock size sleeves, or I'll have to disassemble the calipers to measure them...Once I open them, I can't reassemble without a kit,,, or at least the proper casting O rings... I don't want the car undriveable while waiting for kits..
Anyone familiar with Muskegon Brakes SS calipers??
NOTE... I just called Muskegon Tech again,, and they insured me the calipers are standard size,, and O ring or lip kits will fit!!!! On to the next problem!!!
Changing the system back to Dot 3 may not be too easy,,, not sure how to clean the DOT 5 out of the system, without replacing the MC and lines tho...
some years later since vacuum sux, I put in hydrobooster brakes....tap the pedal and pray your seat belt holds, none of the 'swich/sponge/pray' feeling about if you will actually stop....
I misspoke,,, found the receipts from Muskegon,, I replaced SS calipers in 1990, so it was 30 years ago!!!! I thought that switch also warns if the proportioning valve is not centered? I can't remember how I flushed the lines to use DOT 5 originally (alcohol?), so I may just continue using it, clean the calipers/pistons and throw some new lip seals in until I can get to Carlisle and pick up O ring kits,,
and it tends to leak, so the better way is what I said, just a T splitter in the front and the line to the m/cyl....
rear directly to m/cyl.....
Since it has DOT 5 fluid,,, I decided to just get replacement lip seals, as O rings seem to want DOT3,,, Pulled the R front caliper and found it leaking, so I rebuilt it first,,, Cleaned the SS calipers/pistons,, installed new seals and case O rings, torqued to spec and tested it with vacuum for a few minutes,, held tight,,, So back on the car, with a new hose,,,, tried to vacuum bleed the fronts and can't pull fluid thru the front calipers... Also found teh pedal goes to the floor...
Figured it has something to do with teh prop valve out of center, and read that cracking teh MC lines to prop valve will allow it to center again, and I was able to get fluid thru and bleed teh front brakes,,,, but the pedal is still on the floor...
Not sure where to go next as I've dissembled and cleaned these calipers before, with out all this drama!!!!
Any thoughts?? Its been a while since i worked on these brakes and age has me forgetting simple stuff!!!
Thanks!!!
