PVC delete
Old Jun 28, 2020 | 09:22 AM
Sleper's Avatar
Sleper
I replaced the rubber hose
Old Jun 28, 2020 | 12:47 PM
Yadkin's Avatar
Yadkin
Originally Posted by Sleper
Can I remove my PCV and just put in a valve cover breather and plug carb. Having issues since putting in a 383 striker where oil is being picked up through the PVC and being burnt through the carb?
The PCV system helps seal the oil rings and is important not just for emissions. The system should use full manifold vacuum through a check valve to vent crankcase gasses from a high spot in the sealed crankcase. Usually the high spot is a valve cover. If you are drawing oil into the system then you can install a catch can.
Old Jun 29, 2020 | 08:38 AM
Sleper's Avatar
Sleper
Thanks everyone much appreciated
