Frontend Rebuild
Old Nov 27, 2002 | 10:07 AM
SprintCarDriver's Avatar
SprintCarDriver
Default Frontend Rebuild
Since I have deceided to rebuild the front end is there a kit to put larger rotors on the stock spindles? Would the benefits justify the extra cost? Will my current stock wheels work? My brakes, tho adaquate still suck!..
Old Nov 27, 2002 | 12:10 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: Frontend Rebuild (SprintCarDriver)
If you feel your brakes suck install the hydraboost system and remove that brass block/distribution block/proportioning valve. I have a hydraboost from the wreckers $50 , 4 stainless stock calipers, no brass block and excellent brakes. Forgot I also run organic pads to save the rotors.
My brakes are far better then my wife's new SSEI Supercharged Bonneville.
My brakes were an embarrassment when i let people drive my car. Not anymore . Now I have to warn them to take it easy the first time until they get use to the power.
Old Nov 27, 2002 | 03:32 PM
SprintCarDriver
Default Re: Frontend Rebuild (norvalwilhelm)
Where can I find info on this hydraboost system conversion. Searched the c3 section and found nothing :( . What does it consit of?
Old Nov 27, 2002 | 03:39 PM
norvalwilhelm
You must be very new here. This has been an ongoing topic for the last year. Look in the tec tips. There is alot of material on it there.
Old Nov 27, 2002 | 04:02 PM
ylose's Avatar
ylose
sprintcardriver isn't new...just an infrequent user....where we waste our time on the internet, he is playing with aluminum and his mill...... :lol:
this will help ya sprinter...
http://www.corvettefaq.com/c3/hydraboost.mht
. http://www.corvettefaq.com/c3/hydroboost2.mht
and here is the vault of data kept on the corvettefaq just on brakes. http://www.corvettefaq.com/brakes.asp
:D
[Modified by ylose, 3:03 PM 11/27/2002]
To Frontend Rebuild
