Timing light for MSD
Old Jun 30, 2020 | 04:40 PM
7t9l82's Avatar
7t9l82
Default Timing light for MSD
I have a good INNOVA timing light that has always worked well. It says it's not compatible with multi spark. I know MSD sells thier own half million dollar timing light, anybody know of a reasonable alternative? It just seems like the MSD light is just that and no tach feature etc
Old Jun 30, 2020 | 04:52 PM
stingr69's Avatar
stingr69
You can probably use the one you have but you will want to set your timing at the top of the curve after all the centrifugal advance is fully in. The multispark boxes can throw off erroneous readings at lower RPMs because of the extra spark firings but that problem goes away at 3000 RPM or so where there is only time enough for 1 spark.
I always set my timing at 36 degrees at the top of the curve (3000 RPM when running the old school factory wedge heads. If you have modern Vortec kidney bean chambers you probably only need 32 degrees at full centrifugal.
Old Jun 30, 2020 | 05:10 PM
7t9l82's Avatar
7t9l82
That's what I think I did years ago and that's what I think I'll do. Thanks for confirming my thought.
Old Jun 30, 2020 | 06:24 PM
Mooser's Avatar
Mooser
This just came up recently
https://www.corvetteforum.com/forums...mendation.html
M
Old Jun 30, 2020 | 06:36 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I use the innova and have a 6al2 digital and havent ha any issues. Whats your problems?
Old Jun 30, 2020 | 07:59 PM
Mooser's Avatar
Mooser
Mine (Innova) is moves around at idle about 1-2 degrees with the MSD 6A Digital, and seems (?) to get better when I bring the RPM up but still around a degree off at 3000 compared to the basic light.
Both read exactly the same without the MSD box
M
Old Jun 30, 2020 | 08:31 PM
Rescue Rogers
good to know. I have an old one i should compare them together and see if mine get wonky
Old Jun 30, 2020 | 09:05 PM
69ttop502's Avatar
69ttop502
I use the flaming river self powered light. Works perfect with the ignition boxes.
Old Jun 30, 2020 | 09:14 PM
cv67's Avatar
cv67
St. Jude Donor '05
Wanna loan? Same problem.
Cant tell if its my light or if I got other issues mark jumps all over the place no matter what the rpm.
Old Jun 30, 2020 | 09:19 PM
Mooser's Avatar
Mooser
That's the worst part of it, some seem to be off, others seem to be rock steady, mine wanders around so much I chased problems with idle that weren't actually there for weeks, with points it works perfectly even with HEI
I hate not knowing something is working or kind-of-working
M
Old Jun 30, 2020 | 09:25 PM
7t9l82's Avatar
7t9l82
Ok. Just got an email from an old friend that is who I consider an ignition guru and he said if I have an issue with my light use a separate battery. Not sure how that affects things but if he says try it I'll give it a shot.
Old Jun 30, 2020 | 09:29 PM
Rescue Rogers
M
i understand that
Old Jun 30, 2020 | 09:31 PM
Mooser's Avatar
Mooser
I went with the proform self powered unit from Summit, pretty much the same idea. Matches the innova one exactly when on points
M
Old Jul 1, 2020 | 07:18 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Just buy a cheap Craftsman strobe.....all that is needed. Do not use dial back or digital.....it can be up to 2 degrees off below 3000 RPM......
Jebby
Old Jul 1, 2020 | 07:52 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
With my Innova light, I find that if the pickup clamp just "hangs" on the plug wire, the readings can be way off. But if I gently pull on the pickup wire, the readings are accurate. As stingr69 states, I do a check at 3000+ rpms to verify my total timing.
Edit: I have a MSD 6530 programmable ignition box.
Old Jul 1, 2020 | 08:57 AM
Big Block Dave's Avatar
Big Block Dave
Jebby
Ive got two inductive timing lights that friends have disposed of, to me. A craftsman, and something else called "Fox Valley", and I recently threw out some other relic that ended up in my collection.
Anyway, an inductive timing light and timing tape, or a numbered balancer can't be beat. Ive borrowed dial back craftsman lights and tested them back to back, and did they not give same readings.
Old Jul 1, 2020 | 10:16 AM
cv67's Avatar
cv67
St. Jude Donor '05
Have a craftsman light and the mark jumps around no matter what rpm. Dont know if I have an cam endplay issue or its just the light but msd is too proud $$ of theirs. Runs fine though
To Timing light for MSD
Old Sep 8, 2021 | 01:39 AM
benstorey's Avatar
benstorey
2nd Gear
[QUOTE=Big Block Dave;1601768947]Ive got two inductive timing lights that friends have disposed of, to me. A craftsman, and something else called "Fox Valley", and I recently threw out some other relic that ended up in my collection.
timing light and timing tape, or a numbered balancer can't be beat. Ive borrowed dial back craftsman lights and tested them back to back, and did they not give same readings.[/QUOTE]
There will be differences in the readings. These are two fundamentally different indicators. They work differently.
Old Sep 8, 2021 | 07:02 AM
69ttop502's Avatar
69ttop502
Your light will be accurate at 3000rpm or above where the MSD’s multiple sparks become a single spark. The Flaming River uses its own batteries, so works perfectly with spark boxes.
Old Sep 8, 2021 | 12:18 PM
Big Block Dave
Originally Posted by benstorey
[[color=#000000]QUOTE=Big Block Dave;1601768947]Ive got two inductive timing lights that friends have disposed of, to me. A craftsman, and something else called "Fox Valley", and I recently threw out some other relic that ended up in my collection.
There will be differences in the readings. These are two fundamentally different indicators. They work differently.[/QUOTE]
the two dial back lights gave different readings from each other
