Shim Question
Old Nov 27, 2002 | 12:41 PM
Robd's Avatar
Robd
Default Shim Question
On my January 8th '68 built car I have some questions on the body shims.
In all locations I have the alum. puck shim, all locations have what appears to be a steel shim/washer just slightly smaller in diameter and about half as thick as the alum puck. Some locations have a square thim plate/shim with bent over corners. My question is concerning the grease pencil marked shim count. Which of the previous are counted as shims. ie. mount #4 is square plate, washer looking shim and a alum. puck. Is that shim count for that location 3 ? Thanks in advance.
Old Nov 27, 2002 | 03:40 PM
MasterDave's Avatar
MasterDave
Moderator
Default Re: Shim Question (Robd)
Moving to C3 section, hope you get your answers. :cheers:
Old Nov 27, 2002 | 04:08 PM
68'427's Avatar
68'427
6th Gear
Default Re: Shim Question (MasterDave)
MasterDave,
I apprceiate the intent for moving, however the shimming process would be very similar as C2 therefore I posted in C2, C3, Factory Correct Resto.
[Modified by 68'427, 9:25 PM 11/27/2002]
To Shim Question
