Start
Old Jul 2, 2020 | 04:40 PM
planet-automobile's Avatar
planet-automobile
Default Start
Hi
I have a problem with my corvette 76. if I leave the car one day without starting, it takes a long time to start (about 10 seconds) I think the gasoline goes back to the tank
Old Jul 2, 2020 | 04:46 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Could be the problem. But really, 10 seconds doesn't sound all that bad for cold starting a 40 plus year old carburetorated car.
Old Jul 2, 2020 | 04:54 PM
71chimera's Avatar
71chimera
are you parking on incline w/ nose elevated ?
Old Jul 2, 2020 | 05:12 PM
derekderek's Avatar
derekderek
fuel pump. phenolic spacer. block heat passage in intake. all of the above. none of the above. cranking it until oil pressure starts to climb before firing is never that bad a thing.
Old Jul 2, 2020 | 06:07 PM
Bikespace's Avatar
Bikespace
At least in 79, the fuel filter has a check valve. Swapping this out helped a great deal with my car. Fixing the tuning also helped. Plus the above suggestions.
Still, 10 seconds isn't all that bad really. On a cold engine, pump the gas pedal twice to the floor to reset the linkages, then crank until it starts.
Old Jul 2, 2020 | 07:10 PM
derekderek's Avatar
derekderek
crank 5 seconds then pump a couple times.
Old Jul 3, 2020 | 12:33 AM
hdeyong's Avatar
hdeyong
I've ordered a one-way valve for the fuel line, which I'm going to install between the pump and the carb.
When the car sits for a week or two, the fuel seems to have siphoned back out of the carb. I'm not sure how this is possible, but I know I have to crank the engine over for a while to get gas back into the float bowls. So, the one-way valve should do the trick by not letting the gas back out of the carb.
I think.....
Old Jul 3, 2020 | 02:56 AM
Haggisbash's Avatar
Haggisbash
Once the fuel is in the fuel bowls in the carb it is unlikely that it could siphon back to the tank, there is an air gap between the entry to the fuel bowl and the fuel level in the bowl. Do you give the accelerator a couple of pumps before trying to start the engine? Take the air cleaner lid off when the engine is cold and give the carb a couple of pumps while you look down the carb venturies to see if any fuel is squirting from the accelerator pump nozzles when you do this. If not the fuel could be boiling off when the car is parked up and the engine is hot. If there is fuel in the bowls it should be sufficient to keep the engine running until more was pumped up the line by the fuel pump.
Old Jul 3, 2020 | 08:36 AM
planet-automobile
no it's the same. about 10 seconds
Old Jul 3, 2020 | 08:38 AM
planet-automobile
Old Jul 3, 2020 | 08:40 AM
planet-automobile
yes
​​​​​​it starts better with this method
Old Jul 3, 2020 | 08:51 AM
planet-automobile
I think.....
I am thinking of installing it too
Old Jul 3, 2020 | 09:25 AM
JavaJolt78's Avatar
JavaJolt78
Not a bad idea!!
Perchance you have a vendor and part number to share???
javajolt78
Old Jul 3, 2020 | 09:32 AM
drwet's Avatar
drwet
I would be looking at the carb. I suspect it’s leaking. Ten seconds of cranking is required to refill the float bowls. Had the same problem with my ‘66. It was the carb.
Old Jul 3, 2020 | 09:39 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
It could be just evaporating. I pump mine about 5 times, turn it over to see if it will catch, 5 more pumps to see if it will catch then just 3pumps and repeat. It varies on the weather as to how fast mine is evaporating and how many days since the last drive. once it sounds like theres gas in mine its just 1 or 2 pumps so I dont flood it. I have an Earls check valve in mine and I still have evaporation issues so I know its not syphoning out
One more reason for a Sniper fuel injection next year
Old Jul 3, 2020 | 10:14 AM
drwet's Avatar
drwet
In my experience it takes a week or more for the fuel to evaporate. If it’s doing it in one day, it’s probably leaking.
Old Jul 3, 2020 | 10:24 AM
GUSTO14's Avatar
GUSTO14
This may work, but if you obtain one of these, you may get the same result, without the need to compromise your original fuel line too.
You may be able to find it locally, but if not here's a link...
Good luck... GUSTO
To Start
Old Jul 3, 2020 | 11:01 AM
planet-automobile
Old Jul 3, 2020 | 11:43 AM
Big2Bird's Avatar
Big2Bird
All mechanical pumps have a check valve in, and a check valve out. Thats how they work.
The tank sock keeps trash out.of the pump.
Adding a check valve or foot valve is worthless.
Old Jul 5, 2020 | 05:14 PM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
Might be basic but are you sure your choke is setting before you crank the engine over?
