How will this radiator do?
Old Jul 6, 2020 | 08:27 PM
Cmurray79's Avatar
Cmurray79
Default How will this radiator do?
https://www.championradiators.com/Ch...-row-1977-1982
Turns out I have a leaky radiator. I'm going on a camping trip in a couple weeks and need a replacement before a 2 hr drive in 85* weather.
I have a moderately built L48. Iron heads. I don't feel like I need a 4 row radiator and I don't trust the fitment of cheap ones from parts stores. I am looking for a good value, and this one seems to take the cake. Thoughts?
Old Jul 6, 2020 | 08:43 PM
interpon's Avatar
interpon
Good price..
if usa matters i got the zip dewitts for 399 two core one inch wide..
been happy
Old Jul 6, 2020 | 08:54 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Go for it!
Old Jul 6, 2020 | 09:57 PM
bashcraft's Avatar
bashcraft
Originally Posted by interpon
Good price..
been happy
almost twice as much.
go with the champion.
Old Jul 6, 2020 | 10:14 PM
interpon's Avatar
interpon
again ..if it matters...
to me it does..that is a good price
Old Jul 6, 2020 | 10:25 PM
71chimera's Avatar
71chimera
Are those inlet & outlet dimensions sized correctly for your 79?
Cmurray79's Avatar
Cmurray79
Originally Posted by resdoggie
Go for it!
I went for it. I’ll let update later with how it fits.
Old Jul 6, 2020 | 10:49 PM
Cmurray79's Avatar
Cmurray79
guess we’ll find out. There are plenty of adapter kits i can give a try if it is not exact. My hoses look like they are 1.5 inch. Rad i bought is 1.3 and 1.5
Old Jul 7, 2020 | 09:55 AM
red topless gator's Avatar
red topless gator
I put one in my 74 bout 5 years ago and have had no problems
Old Jul 7, 2020 | 10:49 AM
7t9l82's Avatar
7t9l82
I've got one that is several years old. No issues.
Old Jul 7, 2020 | 11:21 AM
nyciti's Avatar
nyciti
So I know people have them and there is a whole big thread but I had crap experience with champion. Fit is eh and it didn't cool my motor worth a damn. Everything is new in my car I was chasing overheating issues. Tried everything under the twice. Had enough spent the $$ on a Dewitt which I have in my C5. Cooling problems gone. Rad fits like a glove it falls in the car. You get what you pay for. Just my .02 again I know many others on here will say otherwise or tell me I'm wrong.
Old Jul 7, 2020 | 11:34 AM
71chimera's Avatar
71chimera
I've owned only older C3s; dunno, perhaps the newer C3s' hoses have smaller IDs. Perhaps you're golden; hope so.
Old Jul 7, 2020 | 12:29 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I have installed one on a 76'.......it went in ok and the outlets were pointed in the right direction but the tanks on the rad are square and do not come close to fitting in the stock rubber mounting pads.....I had to make my own spacers to make it work. Not sure why they don't have some kind of kit for this because it would be this way on ALL Champion rads put in a Vette.......people here bitch about the fit but this is never specifically mentioned (No I have not read the Champion thread)........
Jebby
Old Jul 7, 2020 | 12:46 PM
mardyn's Avatar
mardyn
Jebby
I had the exact same issues with my radiator replacement... those square end tanks DO NOT fit properly in the saddles as designed for an OEM style stamped tank.
Made some shims to help support it better but still not entirely happy with the end result.
mardyn
Old Jul 7, 2020 | 04:22 PM
Cmurray79's Avatar
Cmurray79
Jebby
interesting. Sounds like i have some fabricating to do. I’ll keep this post updated
Old Jul 14, 2020 | 09:54 PM
Cmurray79's Avatar
Cmurray79
THIS IS NOT DIRECT FIT. Other than that it cools just fine. We'll see how long she lasts.
Old Jul 15, 2020 | 09:06 AM
gjohnson's Avatar
gjohnson
My Champion 3 row needed a little massaging to fit but not a big deal. Cools my 383 just fine
To How will this radiator do?
Old Jul 20, 2021 | 03:01 PM
Cmurray79's Avatar
Cmurray79
Well she lasted a little over a year. I just pulled the radiator and it is leaking from the bottom of the driver side tank. Just gonna weld it and see if that fixes it. If not i’ll be giving Champion a call.
Old Jul 20, 2021 | 05:06 PM
interpon's Avatar
interpon
that sucks..be good th hear update on response.. check the weights of radiators too
Old Jul 20, 2021 | 05:18 PM
Cmurray79's Avatar
Cmurray79
[QUOTE=interpon;1603757443]that sucks..be good th hear update on response.. check the weights of radiators too[/QUOTE
found that its leaking from another spot too. So i’ll be calling them. Disappointed. Maybe aluminum isnt the way to go for a daily driver. I talked to my buddy and he said the way most cheaper aluminum rads are made causes them to become weaker with every heat cycle. Might go brass 3 row.
