Timing Chain
Old Jul 9, 2020 | 12:40 PM
82Other's Avatar
82Other
Backfiring only while warming up. It stops doing ti suddenly and gains about 250 rpm and runs smoothly.
Old Jul 9, 2020 | 12:42 PM
82Other's Avatar
82Other
Yeah I had my limit on this job. Was doing it before the new chain and sprockets, just not as loudly. I have another 82 in my driveway doing the same thing.
Old Jul 9, 2020 | 01:18 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Originally Posted by Jebbysan
I don't give a **** what the video says or who says what. Dot to Dot is TDC #6. 12 and 12 is TDC #1. In both positions, the pistons on 1 and 6 are at the top.....but that is not considered TDC. I have built over 200 Chevrolet V8's from junk to 40k Big Chief engines and this applies to all. You can put it all together dot to dot and the mark will be in the correct spot but if you drop the distributor in pointing toward #1, you WILL be 180 degrees out. Always.
Jebby
Jebby, I think you are confused with this. Chevrolet has always been the cam at 6 and crank at 12 for lining up the timing marks. Now an Olds engine would be 12 and 12.
Old Jul 9, 2020 | 01:51 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
How are you setting timing? Is your mechanical and vacuum advance working? Theres a number of things that can cause backfiring.
Is your backfiring out the carb and dramatic or just a lot popping out the tailpipe?
Old Jul 9, 2020 | 01:53 PM
Rescue Rogers
If it's out the carb I would think to much advance, if it's out the rear I would think it's super lean. If it's when your driving , foot off pedal and winding down on the engine then I would say too rich
Old Jul 9, 2020 | 01:54 PM
71chimera's Avatar
71chimera
Burned valve ? Valve(s) set too tight ?
Old Jul 9, 2020 | 04:09 PM
stingr69's Avatar
stingr69
Jebby is right about the firing position. Crank gear at 12:00 and Cam gear at 6:00 is TDC #6 FIRING position. #1 and #6 pistons are both at TDC but only #6 is in the firing position.
Old Jul 9, 2020 | 04:32 PM
Sigforty's Avatar
Sigforty
Okay, it just seems confusing compared to how I have put together engines. I always do the dot to dot on timing chain setup, but also verify #1 compression before I install a distributor. I've never had an issue with being 180 out that way. I also never had the timing cover off afterwards to see that camshaft could be at 12 o'clock.
Old Jul 9, 2020 | 04:37 PM
KenSny's Avatar
KenSny
Because the distributor never lost its relation to the cam. You installed the chain at #6....and when you did, the rotor was pointing to #6 terminal on the cap.....so no issue.
But if you pull the distributor.....and do dot to dot, then point the rotor toward #1 it will be 180 out. It has to be.
Jebby
That's the way my dad taught me.... We only worked on Chevys, so not sure about other makes.
Old Jul 9, 2020 | 04:40 PM
Rescue Rogers
wrong again....Like I said, pay attention to the manufacturers instructions. 6 and 12 is #1 tdc for a specific chain, Comp Cams is that way set it and throw on the harmonic balancer
https://static.summitracing.com/glob...s/cca-2100.pdf
edelbrock says to rotate it before the damper goes on
https://static.summitracing.com/glob...er-linktim.pdf
Except summit, they pretty much say set the engine at tdc before removing the chain......thats pretty poor instructions if your building a motor
Old Jul 9, 2020 | 04:52 PM
Sigforty's Avatar
Sigforty
Jebby
I now see what Jebby is saying. The edelbrock instructions spell it out perfectly as quoted below.
"TIMING MARK ALIGNMENT NOTE: Alignment of the timing marks as shown below does not always indicate Top Dead Center (TDC) of the number 1 cylinder on the compression stroke. Many engine families (Chevrolet, Pontiac, etc.) will be at TDC of number 1 on the exhaust stroke and the crankshaft will have to be rotated one full turn before the distributor can be installed and timed"
Old Jul 9, 2020 | 04:54 PM
derekderek's Avatar
derekderek
Jebby and confused don't play well together in the same sentence.
  #33
Rescue Rogers
Yes for that specific chain. Comp Cams doesnt rotate their chain so you have to hope that the companies instructions are very good and deliberate or you very well could be off 180*
This is why I always use Comp Cams chains
Old Jul 9, 2020 | 05:31 PM
  #34
stingr69's Avatar
stingr69
Nobody makes them different.
Old Jul 9, 2020 | 05:37 PM
  #35
Rescue Rogers
really then my motor must be running backwards....pretty ggood to, maybe i should just not read any instructions anymore and be more like you clowns
Old Jul 9, 2020 | 08:17 PM
  #36
HeadsU.P.'s Avatar
HeadsU.P.
Dot to Dot assures your eyeball is seeing exactly what needs to be done on the sprockets without error.
Then you stab the dizzy later. Remember? Thumb over the sparkplug hole?
Clocking the dizzy is the least of your worries after you have everything buttoned up; timing set, timing cover, water-pump, balancer, oil pan, Intake, etc.
One tooth off with the chain and everything comes back off.
